Results 1 to 8 of 8
Thread: how many wires
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    how many wires
    hi new to this thread i have a 1997 rover600 ti (turbo) i have been told that i havent got obd-II but after looking under the steering wheel by the throtle i found a conector that looks exactly like obd-II .
    my question is how many wires go into the block because my one only seems to have 3 that i can see and this seems like a very low number for the size of the conector
    thanks
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    ODBII
    All cars built since Jan. 1 1996 have OBDII. So your car has it, if it follows this guideline.
    Can you be more clear about the wires though, I really didnt understand the question ?
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Nov 2004
    southampton (UK)
    hi
    the conector in the car is a big white one with lots of pins but only 3 of the pins seem to be used ?
    The car
    Jun 2004
    NH
    Ahh well not sure about that one.. but check out that web site it will give you a pin out of OBD and you'll probably be able to tell whats comming from those pins.
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Jun 2004
    All cars SOLD in the USA after jan 1 1996 have OBD2, Some that do not exist here in the US and some High-end sports cars that are loophole imported (read as bribing the federal gov't) do not have it.
    Nov 2004
    southampton (UK)
    but it's a rover and it's british and im in the uk
    The car
    Constant Bitrate Gibson99's Avatar
    Aug 2004
    Houston, TX, USA
    Iamthehor has it right - obd-ii is a standard made by CARB - California Air Resources Board. thus it's a US standard, and doesn't have to be on anyone else's cars. that doesn't mean it doesn't exist on other cars though.
    to the original poster - 3 pins is just fine for an obd-ii port. one is data, one's ground, and the other is probably 12v constant. you can safely probe an obd-ii port with a meter to check continuity to ground and existance of +12vdc but don't expect to see much on that third pin with just a multimeter. you might see continuity to ground w/ the engine off, or you may never see anything. it's a serial data line, and it uses chassis ground for its signal ground.
    if you have a friend or know of a shop that has an obd-ii scan tool you could use, try connecting it and see what you get! you may be pleasantly surprised.
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
  1. Power wires inquiry
    By maxxell in forum Power Supplies
    Last Post: 03-27-2005, 04:33 PM
  2. Replies: 16
    Last Post: 07-30-2004, 01:46 PM
  3. Opus Wires Guage Help!
    By mikeyg35 in forum Power Supplies
    Last Post: 04-04-2004, 08:29 PM
  4. Connecting Ignition and Battery ITPS Wires
    By Norrin302 in forum Power Supplies
    Last Post: 03-03-2004, 11:01 PM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 12:13 PM
