Results 1 to 2 of 2
Thread: anyone using DynoJet Wideband O2 App?
    Variable Bitrate lerandell's Avatar
    Mar 2004
    Is anyone using this as a launch app or embedded? I know this is not exactly OBD-II stuff but, for those that don't know the Dynojet Wide Band is used to watch you engines exhaust to see if it is "in the zone" to create the most horse power. Th ewide band is good because it is much more accurate that a stock o2 sensor. anyway, here is the app that the sensor uses. however the sensor box will also connect to a standard electric dash gauge.
    Randell Kelly
    Feb 2005
    I'm using it.
    I think the nicest feature is being able to set the warning light. My truck is running 16+lbs of boost, so I set my light for 12.0 AF, that way if I'm in boost I know that light should be on. It's a nice interface. I can't get the RPM at idle right, but it works everywhere else.
    Still need to hook up the TPS, and MAF voltage.
  1. monitor off app
    By kreyzig in forum Software & Software Development
    Last Post: 12-29-2004, 04:43 PM
  2. [HOWTO] Make a custom external app button
    By netsuo in forum NeoCar Media Center
    Last Post: 11-15-2004, 06:42 AM
  3. [OT - almost] Looking for best way to save App data - is XML OK
    By kingtut in forum Software & Software Development
    Last Post: 07-12-2004, 12:39 PM
  4. External App launching
    By TechToy in forum Media Engine
    Last Post: 05-13-2004, 04:02 AM
  5. new app linux/windows
    By hijinks21 in forum Software & Software Development
    Last Post: 11-18-2003, 08:25 AM
