Results 1 to 7 of 7
Thread: Autotap
    Constant Bitrate pirate_king00's Avatar
    Jan 2005
    Autotap
    Has anyone here used autotap software? Which is the best software out right now for the OBDII?
    I have seen a few dealer sites that use autotap but than hacked the software and put their own name in the title bar.
    Any input on this software or others would be great. I plan on ordering an OBDII scanner/reader soon.
    Jan 2005
    well I just hit autotap's website and looks like you can download the software free. Now not sure if you need a serial key or anything like that. I am waiting for my scanner tool to arrive and I will try it out. I was hopeing that someone has messed with it.
    Oct 2004
    South Carolina
    that looks pretty cool. keep us informed
    Jan 2005
    Well I got my OBD II scanner and unfortunately it doesnt work with autotap. They must have some code embedded on a chip that the software looks for. So just using the software from obddiagnostics, which is what Frodo is in the process of making a front end for.
    Oct 2004
    I believe autotap's software will only work with their hardware.
    Jan 2005
    I am sure that one of these programmers on this site could probably disassemble the code and bypass it. The software is free to download off autotaps website. I did see another company reselling autotaps software but they had their name located on the menu bar and also using homemade scanner tool. So I am sure they did this.
    Feb 2005
    I really wonder if other software will work with autotap's hardware.
  1. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2004, 12:13 AM
  2. could you use this to monitor your car
    By Redmachine in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-14-2004, 09:15 AM
  3. scantool vs autotap
    By shakes in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-26-2003, 11:00 PM
