Results 1 to 10 of 11
Thread: can you adapt a serial device to USB? (ODB-II)
    Oct 2004
    South Carolina
    Right now, my laptop has only 1 serial port, and I'm using that as an infrared receiver..
    in the future I want to add ODB-II readouts, etc.. and the only kind of ODB-II interface devices I've come across plug into a serial port...
    Is there a way to adapt these things to USB?
    thanks for any information!
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    USB to serial dongles can be had for ~$10 on-line or at any computer store.
    Oct 2004
    South Carolina
    I know they exist, I just wasn't sure if it would work for an application like this that's all
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    And if you plug it in via USB and the software doesn't want to recognize it, just use a USB to Serial simulator driver to make the software think you've got it all hooked up through Serial.
    Mar 2004
    Redondo Beach, CA
    @Skipjacks: LOL, ALL USB->Serial dongles include a virtual COM port driver. That's the point!
    @matress: The dongles support ANY serial hardware. The real issue is software. As long as your software doesn't try to do direct hardware access (unlikely), it will work fine. I'd say there is > 99.9% chance it's going to work.
    Low Bitrate Goofus's Avatar
    Feb 2005
    Durkadurkastan, FL
    I use these to connect to various brands of PLCs. This is the only adapter that has worked with every one of them.
    http://www.cdw.com/shop/products/def...spx?EDC=555201
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    i have a serial touchscreen, it won't wake from hibernation, I have to restart the computer every time. Do you think if I were to switch it from serial to USB with one of thiese that it would solve the problem?
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by TimmyM
    Well since everyone jumped to answer, I decided to find out my self. And it does! I moved my serial TS over to the serial/usb adapter and re-installed the TS drivers (it's the only way to pick the com port number) and it worked fine! I've gone into hibernation and back out several times without any problems.
    Thanks for the info Tim.
    Ah, no problem Tim, It was the least I could do for such a nice guy and all.
    Oct 2004
    South Carolina
    lol good information if I ever get a lilli or xenarc
    Aug 2003
    Federal Way, WA
    you probably won't need it, I believe lilli and xenarc use USB TS to begin with. My monitor is a old POS monitor and it uses serial.
    It may work with other serial devices that have a simular problem.
  1. Problem with USB to serial converter
    By openminds in forum GPS
    Last Post: 07-29-2011, 12:32 AM
  2. ODB II and GM DIC
    By cw95403 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-22-2008, 02:40 AM
  3. What the cheaper and best ODB II to buy?
    By TimStark in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2005, 01:43 AM
  4. USB device not detected after hibernate?
    By rbarr110 in forum Software & Software Development
    Last Post: 02-14-2004, 02:01 PM
  5. USB to serial
    By Sleeka in forum General Hardware Discussion
    Last Post: 12-24-2002, 04:55 PM
