So anyone used it yet?
Current Status: For Sale
Specs
- 1.5Ghz Toshiba Laptop (available - no screen)
- Indash Motorized 7" VGA TS
- DeLorme GPS (sold)
- Power Inverter (sold)
- Pioneer HU (sold)
Originally Posted by carabuser
Yes!!!
I'm using it! It works - My app isn't finished yet, but it's a re-hash of this:
OBDII / Elm MPG meter. Almost working but not quite!
The OBDII stuff is working very well. I've successfully had it running for hours on end pulling out the data. My MPG calculations seem to be a bit iffy though - I am having trouble finding a comprehensive list of all the basic formulas for temp, mass air flow etc for when I'm converting from the output long to it's 'real' value! I found one a long time ago when I first started on this, before your VB6 class, but can't find it now, so having a little trouble double checking everything.
I haven't tested standby/resume properly yet - my only try resulted in failure but I was thinking about polling for the standby system call and disconnecting, then on resume reconnecting if it causes any issues - my main thing is getting the instant MPG quick and reliable.
But yes... It works!
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
Any progress on this? I'm wondering if MPG calculations are possible using OBD-II.
Originally Posted by knubile
The problem I have with this is the air flow sensor is very optimistic, and you probably run richer than this formula indicates. It says I average around 60-90MPG when cruising on the hwy and up to 200+ MPG when coasting. However, it does change when you have the pedal down, etc. I forget where I stole this code from.PHP Code:Function GetMPG(tMAF As Variant, tSpeed As Variant, tLTFuelTrim As Variant) As Variant
''MAF is maf_air_flow sensor. To convert from what the OBD returns, value=OBDData * 0.01
''tSpeed is vehicle speed in MPH. To convert from what the OBD returns, value=OBDData * 0.621371192
''tLTFuelTrim is long-term fuel trim. To convert from what the OBD returns, value=0.7812 * (OBDData - 128)
If IsNull(tMAF) Or IsNull(tSpeed) Or IsNull(tLTFuelTrim) Then
GetMPG = Null
Exit Function
End If
Dim tMPG As String
'' Do MAF over an hour
tMAF = tMAF * 60
tMAF = tMAF * 60
'' Turn into KG/litre equivalent
tMAF = tMAF / 1000
'' Get petrol flow based on 14.7:1
tMAF = tMAF / 14.7
'' convert litres to gallons
tMAF = tMAF * 0.219969157
'' convert long term fuel trim to percentage
tLTFuelTrim = (tLTFuelTrim / 100) + 1
'' Calculate MPG
tMPG = (tSpeed / tMAF) * tLTFuelTrim
GetMPG = FormatNumber(tMPG, 1, True, False, False)
End Function
Originally Posted by Erorus
It looks like my botched attempt at MPG conversion I think.
I didn't think it was accurate as it could be either, and haven't actually used it in real-life.
Any idea what could be done using the OBD to get a more accurate measure?
does anyone have this class working?
If so, could you post a sample app to be looked at?
Thanx
Hi guys, I am programmer too. While I am mostly involved in database/plsql programming I have fooled around with C/C++ and some VB. Assembly too!
Can anyone tell me if there would any substantial performance difference between a typical serial communication tool for OBDII written in C/C++ versus VB/.net ? Think CAN too.
Sample app that I am trying to get to work with this class, I am not sure how to "pass a mscomm control, the port number, and a timer control to it" ?
Can some one help get me started with this?
