Results 1 to 10 of 20
Thread: anything out there for 94 ford explorer?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hows every1 doing i had a question bout obd stuff i got 1994 ford explorer xlt v6 4L i want to get some stuff off the ecu and onto the pc so i can view all the specs and stuff when im driving around is there any way at all to do this i couldnt find anything on this topic :-( help me out please!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Short and Simple: The standard don't exist until 1996 which called OBD2.
    If you are good enought (software and hardware) and if your car has OBD1 and if you are good at you maybe able to find some info regarding to that exploder.
    With that many AND , you are better off forget about it. If you still want that stuff, sale the car and get one at is 1996 or newer.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    hmmm yeah thats what i was thinking just skip it but how can i find out if i got OBD1? where should i look?
    Raw Wave lostreception's Avatar
    NY
    there will b a plug that looks like this
    http://www.home.aone.net.au/techedge...e/con12pin.gif assuming your car was made in the us (gotta love those imported fords)
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Dec 2004
    pic
    oh crap yeah i found that plug some1 told me it was prolly for something ford didnt put in your car heres a picture of it
    NY
    what type of engine do you have
    also look under your seat (i think thats where it is) for your ECU (on board computer) not the one you put in and check to see what your ecu number is do some searching i think ull find u might be able to integrate OBD-I
    i just hooked up my cable today and am working the bugs out i have a 1990 and just your standard 5.7 lt 350
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Dec 2004
    ive got a v6 4L engine ill check under my seat and ill try to find something on my ecu piece ill check right now its already opend up and everythin thanks keep em comin tho
    also once i find the plug what should i do then do i have to make a cable or what?
    Dec 2004
    hey i couldnt find the plug under the seat but there is a label on the ecu want the numbers?
    Newbie jyaron's Avatar
    Aug 2004
    Post
    Quote Originally Posted by xdjxklusivex
    Check under the hood.. towards firewall. You have EEC-IV.
    6-pin connector with auxiliary 1-pin connector which is shorted
    to ground to run KOEO/KOER tests.
    Also, you may have another 6-pin connector for ABS tests.
    Aug 2004
    Post
    This is not a GM ALDL connector... as described previously.
  1. 1994 Ford Explorer XLT CAR PC - LOTS OF PICS!!!
    By xdjxklusivex in forum Show off your project
    Last Post: 09-04-2009, 01:07 PM
  2. 96 Ford Explorer Premium Audio System Advice
    By tczbu in forum Car Audio
    Last Post: 04-13-2008, 07:37 PM
  3. MACH stereo in Ford Explorer
    By seven10split in forum General Hardware Discussion
    Last Post: 07-11-2005, 02:59 AM
  4. 1996 Ford Explorer Eddie Bauer
    By Prindle19 in forum Show off your project
    Last Post: 01-19-2005, 07:46 AM
  5. 1996 Ford Explorer Eddie Bauer design help
    By Prindle19 in forum General Hardware Discussion
    Last Post: 12-28-2004, 10:26 AM
