Results 1 to 3 of 3
Thread: Obd 1
    Mar 2005
    Smile Obd 1
    hey awesome site, just what i have been looking for.
    i've put the engine from a 1989 buick le sabre (3.8 V6) into my kit car. i am currently in the process of building a computer for the car. i will transfer the diagnostic plug and would like to monitor as many gauges as i can on the computer screen (15" non touchscreen LCD).
    i am also currently fabricating a new dashboard and would like to eliminate as many gauges as i can. i would ideally want only the tachometer and have fuel, oil pressure, voltage, and whatever else i can display on the screen.
    what data can i receive from the OBD 1 harness?
    i think there were only 3 or 4 wires connected to the harness.
    since my fuel guage is in the gas tank and does not go to the computer, is there a way to input the fuel level to the computer via another serial, usb or any other kind of input?
    thanks,
    rob
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Man oh man, if you find out the answers to this you will be my hero!! I have been looking for the same thing, but have come up blank. Good luck!
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
    Apr 2005
    There is a lot of info about this out there. A quick Google search on OBD1 or ALDL will yield what you are looking for. The place I got my cable has a boatload of links which point to free software for your laptop as well as trouble codes. Try www.aldlcable.com as a place to get started, but you can go from there to just about all the info you need. It is also a pretty good how-to for getting started.
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  3. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 03:47 PM
  4. ? Potential damage to Carputer if dealer connects OBD device ?
    By SAScooby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-08-2004, 01:56 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
