Results 1 to 2 of 2
Thread: P0851 Park/Neutral Switch Circuit Low
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    A shot in the dark, but does anyone know what this error code means? I know it's got something to do with the sensor that detects if the car is in park or neutral allowing you to start the car. What I dont know is the the "low" means.
    Thank you
    Jan 2003
    Westland, MI
    "Low" is the same thing as grounded - either a faulty neutral safety switch or a faulty parking brake switch. If the "brake" light is not showing on your dash, it's most likely the neutral safety switch. Take your car somewhere you won't run into anything and try to start it in drive or reverse. This will tell you for sure if it is shorted out. If it was not working at all, the car wouldn't start in park or neutral.
    Good luck
  1. Replies: 7
    Last Post: 12-14-2009, 08:34 AM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. Savage Switch Botton Group Buy via UK's
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 01:13 AM
