Can this circuit be used with microcontroller???
i mean after MAX232, can i interface it (DB9) with my microcontroller??
will it work for me? or its just for VAG-COM type scanners or testers???
I've tried with several VW and SEAT, it works perfectlly, it's really fast but I can't find a Renault soft....:S:S:S
You don't need to use MAX232 if you are interfacing the MC33290 with a microcontroller. You just connect it directly to your micro's pins.
Keep in mind that the MC33290 is a "dumb" level shifter, it simply converts your TTL to ISO 9141 levels and provides some protection.
Vitaliy
— OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
its possible read the trouble codes of ecu?
thanks
yes its possible
and the squematics? I find no information about
