Results 11 to 20 of 22
Thread: Skinnable OBD software
  1. #11
    Mar 2004
    Metamora, MI
    I wouldn't call damping delaying. I would call it minimizing amplitude shifts over short term spikes. When an analog meter gets a "jolt" of signal, it immediately responds. Just not as dynamically as the signal implies due to it's mass.
    The recording was taken with an Ease Diagnostics Wireless Vehicle Interface. www.obd2.com and graphed with their Pro Scan Tool software.
  2. #12
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    thanks mods for deleting that crap
  3. #13
    Jan 2003
    Ruston, LA
    Quote Originally Posted by antimatter
    np
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #14
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Frodo & Ziplock... thanks for maintaining the peace! I'll send some your way.....hhehehe
  5. #15
    Low Bitrate Erorus's Avatar
    Feb 2005
    NEPA
    Glad to hear it's truly multithreaded.. that's how one should write stuff like this that writes asynchronously to a port. (My VB6 class isn't multithreaded b/c VB6 can't really do threads.)
    Instead of waiting 300ms to send the next command, may I suggest just waiting until you get the ELM's prompt ">" back and then send the next command then? I think the ELM won't send a prompt if it can't accept the command; correct me if I'm wrong.
    Any luck using the ELM in binary mode? Supposedly it's a little faster but I didn't have the patience to code for it.
    Finally, there's gotta be some .NET class for serial I/O where you don't have to rely on an ancient ActiveX component. I have little .NET experience so I can't really help find it, but there's got to be something out there.
  6. #16
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Erorus
    The 2.0 betas have native .NET serial libraries I believe.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Feb 2005
    Hey guys,
    Here are the sceen shots from the app i made. I used C# and driect3D for the gauges. For the serial interface I used a winapi wrapper. I'd be glad to help out with the development and share my code if anyone would like.
    Let me know what you think about the gauges. It took me a while to construct the meshes. This was my first direct3d project.
    -joe
  8. #18
    FLAC Chairboy's Avatar
    Jan 2004
    You're a stupid DUMBASS for using OBD-II (which is worthless) to measure RPM! I RULE YOU! Suck it. Suck it dry!
    heh, the thread felt empty without JTP, thought I'd fill in for him since he's missing. Looks nice! Which interface? ELM?
    Chrysler 300 - Fabricating
    http://hallert.net/
  9. #19
    Feb 2005
    yeah ELM. I've only tested with elm 323, I only have japanese cars for testing.
    Why would i even need RPMs its right there on the dash .
    This systems does work on a threaded model that waits for the > signal from the chip to trigger the next data request.
  10. #20
    Newbie slahti's Avatar
    May 2006
    Florida
    OBD2 Speed RPM
    Hello I have a quick question regarding OBD2 I have wrote a little interface to return rpm and speed problem is how do you return BOTH
    I have tried everything 2 different timers and a million different things.
    Please send some samples of how to poll RPM and SPEED at the same time in .net
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. Skinnable OBD II Software
    By antimatter in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-11-2006, 09:55 PM
  3. Looking for Non ELM software for OBD II
    By Refael Azi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 11:32 AM
  4. my OBD II Software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-06-2005, 03:53 PM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 09:03 PM
