Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Skinnable OBD software
  1. #21
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    With OBD-II you're allowed only one outstanding request. Try using a mutex to prevent your timers or threads from accessing the vehicle simultaneously. Also if there's more than one ECU on the vehicle, you should wait for all responses before submitting a second request.
    Typically it's easier to keep your code single threaded. I've created several .NET examples for Mongoose. Here's a snippet of how I make an OBD-II request on J1850VPW:
    Code:
    uint ProtocolID = J1850VPW;
    // Clear any messages received before this request
    PassThruIoctl(ChannelID, CLEAR_RX_BUFFER, NULL, NULL);
    // Mode 01: Request vehicle data
    numMsgs = 1;
    Msg[0].ProtocolID = ProtocolID;
    Msg[0].TxFlags = 0;
    Msg[0].Data[0] = 0x68;	// Header
    Msg[0].Data[1] = 0x6A;
    Msg[0].Data[2] = 0xF1;
    Msg[0].Data[3] = 0x01;	// Mode 01: Request vehicle data
    Msg[0].Data[4] = PID;	//   PID: 8-bit
    Msg[0].DataSize = 5;
    PassThruWriteMsgs(ChannelID, Msg, ref numMsgs, 100);
    // Wait P2_J1850_MAX (100ms) for a response from the ECU
    timestamp = (uint) Environment.TickCount;
    while (((uint) Environment.TickCount - timestamp) < 100)
    	numMsgs = 3;
    	PassThruReadMsgs(ChannelID, InMsg, ref numMsgs, 100);
    	for (i=0; i < numMsgs; i++)
    		if ((InMsg[i].RxStatus & (ISO15765_PADDING_ERROR | TX_DONE | RX_BREAK | START_OF_MESSAGE | TX_MSG_TYPE)) == 0)
    			if ((InMsg[i].Data[3] == (mode + 0x40)) && (InMsg[i].Data[4] == PID))
    				// Valid response. Restart the P2_MAX timeout.
    				// Should improve this code to wait for other ECUs instead of returning immediately.
    				switch (size)
    				case 1:
    					value = (UInt32) InMsg[i].Data[5];
    					return PASS;
    				case 2:
    					value = (UInt32) (InMsg[i].Data[5] << 8) | InMsg[i].Data[6];
    					return PASS;
    				case 4:
    					value = ((UInt32) InMsg[i].Data[5] << 24) | ((UInt32) InMsg[i].Data[6] << 16) | ((UInt32) InMsg[i].Data[7] << 8) | (UInt32) InMsg[i].Data[8];
    					return PASS;
    				default:
    					// This code handles only 1, 2, and 4 byte responses.
    					value = 0;
    					return FAIL;
    // We exited the loop for a timeout. Indicate failure.
    value = 0;
    return FAIL;
  2. #22
    Jun 2007
    Anyway of changing this code for VB^?
    I have not used .net and this is the issue I am running into, I need a way to hold second mscomm command until receiving reply from first (and holding third command until receiving reply from second etc etc)
    Quote Originally Posted by joeyoravec View Post
    Code:
    numMsgs = 1;
    Msg[0].TxFlags = 0;
    	numMsgs = 3;
    				switch (size)
    				case 1:
    					return PASS;
    				case 2:
    					return PASS;
    				case 4:
    					return PASS;
    				default:
    					value = 0;
    					return FAIL;
    value = 0;
    return FAIL;
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. Skinnable OBD II Software
    By antimatter in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-11-2006, 09:55 PM
  3. Looking for Non ELM software for OBD II
    By Refael Azi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 11:32 AM
  4. my OBD II Software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-06-2005, 03:53 PM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 09:03 PM
