Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Skinnable OBD software
    Feb 2005
    Because of the software I found is not very usable at my carPC, I designed my own software, with a bigger interface.
    Now I have a last versión, skinnable and multilanguage software.
    The software uses the elm interface.
    It's multithread: the principal thread reads from the interface, another thread writes to the port, another display the vehicle speed, other display the motor speed, and other, at the start time initializes the interface.
    The software is customizable: always displays the vehicle speed and the motor speed, and the other info are the pids the user wants to display.
    The software is skinnable, The layout of the software is defined at the obd.skin file. It's possible to switch between two skins, one for the day and other for the night.
    Also, the program is multilanguage, I have the spanish and the english languages, but other are simply to add. Within the file idiomas.ini we will put the languages we are supporting, and we have some files with the name of the language and some diferent extensions with the infos (.obd and .pids). Also we have the file settings.ini to configure some settings.
    The software also display if the MIL light is active and the diagnostic trouble codes present (DTC's).
    We can configure some timeouts to suit to our car and there is a debug mode to display the raw responses, so we can adjust the timeouts.
    You need the .NET framework to use it, and you also need to register the NetComm.OCX (regsvr32 netcomm.ocx).
    You can download from: http://212.145.142.35/bp/obd.nsf/obd.zip
    Regards
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    screenshots?!?!
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    amazing! gonna test it out VERY soon! cant wait!
    @josh: this is dependant on the interface... I think the elmscans are 1hz or 2hz... that is, one sensor data per second (or 2 sensors per second) This means that if you have speed and rpm, one of them will be updated at each second, which would take 2 seconds to have both updated. (I'm pretty sure of this, although if we can get more updates I would be really happy! ehhee)
    FLAC Chairboy's Avatar
    Jan 2004
    The refresh time is probably better then that if you apply some logic to it. For example, there should be at least three priority levels assigned to various gauges. RPM and speed should be refreshed every time, for example. The check-engine light should be checked too. That's three things that would be checked every time. All the other things, like oil temperature, etc, can be checked less often. Maybe once every 5-10 seconds. There's nothing that will happen that will make your water temperature spike in 5 seconds, for example, because the physical sensors have smoothing logic in them to keep the needle from bouncing around.
    Finally, you can check all the rest of the stuff in increments every half minute or so. If it's not vital and doesn't change fast, you don't have to update it all the time.
    The reason to monitor whether the check-engine light is on, btw, is simple. If it is, then something bad is happening, and that should trigger a new sequence of scans. If it lights up, your interface should first alert you, then scan every item on the OBD bus. That'll take a few seconds, but display the data as it comes over the pipe, and highlight any that exceed known good tolerances or are in an error condition. At this point, getting fast refreshes on speedometer/tach data is secondary to getting the whole picture.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Feb 2005
    The timing is:
    - ask for vehicle speed
    - wait 300 ms (configurable timeout)
    - ask for engine speed
    - wait 300 ms
    - ask for another pid
    so we have the vehicle speed every 900 ms.
    the screeshots are taken from my desktop, not from the car, I added the speed values over, and I didn't add values for the other pids
    Regards
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    This is a good little software but this program sent my m10000 cpu from 112f to 160f. Can you rewrite this in vb6 so it doesn't kill my cpu everytime i run it.
    Jan 2004
    Quote Originally Posted by joshthepilot
    I would say speed and rpm need to be updated constantly for the smooth look. 2 for speed and 2 for rpm in one second? You have no standards for quality apparently.
    Yes, and like I said, those would be the ones that should get sampled all the time. To make it look smooth in the animation, you use trend data. The only reason your animation looks jumpy is because you were only displaying the actual data as it came in. If you plotted the curves and applied a smoothing function, you could have needles that bob around organically using the datapoints being provided.
    I don't think the personal attack is really warranted, this is a matter of technology implementation. In regards to me having no sense of quality, that's kind of inaccurate. I'm actually a software quality engineer, and my resume includes managing the QA for releases of some pretty darn succesful software, some of which you may have installed on your computer.
    http://hallert.net/
    São Paulo, Brazil
    Guys guys... no need to freak out on each othre!
    Chairboy, ur almost at post#1000! eheheh congrats!
    You are both correct... Josh is saying that 2 updates per second would make a jumpy gauge, Chairboy is saying that you should update it 2 times per second, but program the gauge to actually take .5 seconds to reach the last value that just came in... that would make it smooth it out...
    Jan 2004
    Ok, except since the RPM and Speedo are the two highest priority items, they'll never be superseded by anything else. Anything else I can help with? You seem awful comfortable stating 'that'll never work', and 'you're an idiot for trying to make that work'. The confidence you have in your ability to find the One True Solution is admirable, if misplaced.
    http://hallert.net/
    Mar 2004
    Metamora, MI
    Here's a sample recording. You can see the resolution of the RPM. Each dot is a data sample. The graph line "connects the dots". As you can see, it's pretty smooth. Much more accurate than an analog meter which by it's physical nature is damped.
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. Skinnable OBD II Software
    By antimatter in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-11-2006, 09:55 PM
  3. Looking for Non ELM software for OBD II
    By Refael Azi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 11:32 AM
  4. my OBD II Software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-06-2005, 03:53 PM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 09:03 PM
