Results 1 to 8 of 8
Thread: OBD-II Problems
    Newbie Chicco's Avatar
    Apr 2005
    OBD-II Problems
    i'm sorry if someone as already ask this question...
    i know something about the car chip tuning and i know that if something happens while you are writing the code on the chip, somatimes you have to change it. so i'm asking if is it dangerous to keep connected the pc to the OBD port (and so to the chip) while the car is moving... ??? can if have problems?
    thanks, Chicco
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Well, the OBDII software here doens't write anything.
    Apr 2005
    well, i know that it doesn't write anything, but if i send a wrong OBD message request is not a problem? and if the pc switches off during the connection is it dangerous?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Chicco
    It shouldn't be dangerous. Isn't the car's ECU write once anyways?
    Apr 2005
    it depends from the chip model... the olders were Read Only, but the last are EPROM (Erasable Programmable ROM) or Flash ROMS...
    Jul 2004
    Berkeley, CA
    Then figure out which type your car has
    FLAC Chairboy's Avatar
    Jan 2004
    I posted this on the Regal forum, may be of use to y'all:
    http://www.regalgs.org/forum/viewtopic.php?t=20477
    Chrysler 300 - Fabricating
    http://hallert.net/
    Apr 2005
    Quote Originally Posted by Chairboy
    interesting, thanks!
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  4. FS: OBD II ISO - Digimoto/Scantool
    By ELEmental59437 in forum Classified Archive
    Last Post: 07-22-2004, 12:22 PM
