Results 1 to 6 of 6
Thread: Where to start?
    May 2005
    Where to start?
    Hi there I am very interested in connecting my ECU or ECM system to my carpc but at a loss to where to start.
    I have a 1999 Mitsubishi Colt Rodeo 4X4 double cab pickup
    http://www.mitsubishimotors.co.za/co...odeo_intro.asp
    My first question is whether I have OBDII on this car. Most of my reading (yes I have done some reading) suggests that my car does have OBDII. My first problem is trying to find the port (ie the plug) where one would connect a harness/cable to.
    I also have a piggyback computer called Unichip
    www.dastek.co.za
    This has a open plug which I suspect is used to "program" the Unichip.
    Once I have found the OBDII port my next challenge would be to find the cable and software that would allow me to monitor the engine/car parameters.
    Where do I start to look for specs on my particular car's ECU? The local guys are very unhelpful/clueless about how this is done.
    Any pointers would be appreciated
    Manie
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    first, open the bonnet, there should be a plate with the engine info, it should say OBD-II on there if it is.
    as for the port, it will be close to the driver, look down by the pedals, behind the ashtray, undre the dash, places like that.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    May 2005
    Have found OBD port. Engine plate gives no indication of OBD type. According to digimoto I have a Type A J1962 connector that uses the ISO standard.
    Where to now?
    Should I buy a cable/package from someone like Digimoto and try it out?
    With all these cables/harnesses and software solutions around - which one should I try first?
    Thanx
    May 2005
    I bought an ISO interface from scantool.net but cannot get it to work properly (BUS INIT ERROR). Can anybody suggest how I can get it to work?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Have you tried the Scantool support site? There's a troubleshooter there.
    Want to:
    May 2005
    Very frustrated
    After much research and emails I am now quite certain that my car is OBD2 compliant using ISO as the protocol but I still cannot get my scantool to communicate with my ECU (BUS INIT....ERROR) . All the right lights flash and the tool is working (tried it on another car).
    I do have a Unichip fitted www.dastek.co.za and was wondering whether this piggyback chip is causing the problem?
    Scantool have offered to refund me but I am still keen to try and get it to work. Any help would be appreciated
    Regards
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 09:44 PM
  2. PW-120-M start question
    By JosepZ in forum Power Supplies
    Last Post: 02-06-2005, 05:46 PM
  3. donīt start
    By martin83 in forum Power Supplies
    Last Post: 09-13-2004, 02:24 PM
  4. Carputer and music start
    By asci01 in forum Newbie
    Last Post: 06-20-2004, 09:22 PM
  5. Replies: 3
    Last Post: 05-04-2004, 04:24 PM
