Results 1 to 7 of 7
Thread: 2005 Volvo S40
    May 2005
    2005 Volvo S40
    Is this the ODB-II connector? The picture right below the steering wheel on the left.
    If so, anyone know what protocal it uses? I read about checking the pins but Im not sure which pin is #1,#2 etc.
    May 2005
    bump, anyone? :-\
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    yes!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    looks like it
    肚子笑痛了
    S60 Install
    Jan 2005
    Istanbul/Turkey
    Quote Originally Posted by silv3rman
    It's same with eu ford models... u may use that convertor kit. I already use it..
    http://www.ozenelektronik.com/index2.php
    Jul 2005
    The communication protocol is
    ISO 15765-4 29 bit adressing for CAN.
    You may need a CAN bus adapter depending on the hardware you use.
    Krille
    Forgot to attach pin description, see picture below.
    May 2005
    Thanks guys!
  1. OBD port on '03 Volvo s40
    By johno12345 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-05-2009, 09:10 AM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  3. ** Volvo C70 SC-805 Head Unit & AUX In **
    By billyb0b in forum General Hardware Discussion
    Last Post: 02-13-2007, 01:04 AM
  4. 2 Questions Probably Easily Answered
    By silv3rman in forum Newbie
    Last Post: 06-05-2005, 04:41 PM
  5. 2005 Volvo S-40 Help
    By silv3rman in forum General Hardware Discussion
    Last Post: 06-01-2005, 07:12 PM
