Results 1 to 3 of 3
Thread: diagnostics port y-adapter?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Does anyone know if there is (or if it's even possible) a diagnostics port y-adapter. so you can plug in two things to a single diagnostics/obd-II port?
    Thanks,
    Scott
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2004
    Metamora, MI
    I believe Networkcar.com (purchased by Reynolds and Reynolds a few years ago) had a plug that their onboard "telematics" unit plugged into the standard OBDII connector. Then, it also had a female end for a technician scan tool to plug into. But, I am sure you can't use both at the same time if that is what you are after.
    Dec 2004
    Los Angeles Ca
    thanks for the link, i'll check it out. i dont need to use it at the same time. basically i have a 'window valet' which allows me to roll up my windows through my key fob. It plugs into the diag. port and i'd like to eventually add obd-ii to my system (when centrafuse supports it) and not have to lose that gadget.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  3. wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
    By mattress in forum General Hardware Discussion
    Last Post: 04-05-2005, 07:15 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
