none of them tune the engine. They only read the engine diagnostics through the OBD port. It may be able to reset a trouble code, but that's about all.
Hi I am New
Just to findout i have by combo packages From scan tool.net but cant tune my car my car mitsubishi EVO VI Why ? Or software not support. Maybe i need other software ? Pls show Links Thanks
TQ
softneed
"Tuning" requires reconfiguring the controllers firmware (flash) program. To reflash a controller takes a "reflasher" and the calibration flash file. Not for the DIY'r and significantly beyond an "OBDII" scan device capabilities.
Thanks for youre reply
What about if i want to increse the idering how ? B,coz RPM too slow
TQ
Softneed
that's a question you need to ask on an automotive forum, not on a car computer forum... it's not something you'll be able to do through OBDII, that's for sure.
But don't take it from me! here's a quote from a real, live newbie:
eegeek.netOriginally Posted by Viscouse
Thanks Evandude
That why i say I Am NEW any how Thanks
TQ
softneed
forums.evolutionm.net
some obd devices can actually pass parameters back to the ecu to increase idling and set a default timing value
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
Each vehicle idle is set differently. Assuming your engine is mechanically sound (good compression, no vacuum leaks etc), then you might look into the Automatic Idle Speed (AIS) motor to see if it is able to modulate the amount of air at idle which is how the ECU controls the idle speed. If your "idle" screw on the throttle body is out of adjustment, ie the minimum airflow adjustment then you can have idle issues too. Carbon buildup in the throttle body can also affect.
Bottom line is get a mechanic friend to take a look with you.
