Results 1 to 5 of 5
Thread: Is there a new ODB standard?
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    I read somewhere that the 2006+ vehicles are supposed to support a new data standard. seeing as I have a 2006 Toyota Solara I wanted to make sure before I dropped money on an interface that wouldn't work.
    Anyone hear anything about it?
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
    Nov 2004
    Cali
    Quote Originally Posted by Hcomplyr
    CAN? 2008?
    I have found you an argument; I am not obliged to find you an understanding.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    It is not a new "standard" but a faster abetter way to do what it already does. The CAN interface (controller area network) is a different way for the different systems to communicate with each other. The "old" standard was a simple serial interface. To communicate with the "new" standard cars you will need a CAN enabled interface. Most scanners can be retrofitted with an adapter that will allow them to with these vehicles.
    You can read about it here.
    http://www.interfacebus.com/Design_Connector_CAN.html
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Jul 2005
    Cleveland Ohio
    No, it is going to be the same. The new parts of OBDII is something called Mode $06, its not exactly new, but it isn't used much.
    Here is an article my teacher wrote on it.
    http://asttraining.com/Files/Mode6%20OBD%20II.pdf
    Nov 2004
    Cali
    Quote Originally Posted by Eclipsed830
    So i just wasted several minutes of perfectly good time and nowhere in that article does it ever say about it becoming a standard in 2006 or any other point of time. Care to give some useful links?
  1. How to use a standard atx ps on a compaq mobo
    By tastyratz in forum Power Supplies
    Last Post: 01-07-2010, 09:02 AM
  2. Celeron mobile cpu on a standard s478 board
    By GuiltyLionel in forum General Hardware Discussion
    Last Post: 09-27-2005, 04:05 PM
  3. Standard HDD to FDD power adaptor?!
    By coachreed in forum Power Supplies
    Last Post: 06-10-2004, 06:11 AM
  4. Newb question about standard psu's
    By newbiemcnewb in forum Power Supplies
    Last Post: 06-06-2004, 11:05 AM
  5. Replies: 0
    Last Post: 03-08-2004, 02:14 PM
