Results 1 to 5 of 5
Thread: Have You Seen This OBD PCMCIA Connector?
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Does anyone recognize what OBD package this might be from this picture? This is all the detail I have for now and I cannot access the PC to remove the card and take a look. I was wondering if anyone can comment if this is a prettyy standard connector, whether these things are usually supplied in PCMCIA form and so on.
    Once installed how does an OBD connection appear to the PC? Is it a COM port maybe? This card runs with specialized diagnostic software, I'm wondering how accessible replacement parts would be.
    Jul 2005
    Rosemount, MN
    Chris,
    That looks like a standard 9 pin Serial Port PCMCIA card. I do not think that is special for OBDII diagnostics. The black OBDII cable itself does not seem familiar to me, but that might not even be an OBDII cable at all, it could be the back end of a standard Serial cable for all I know.
    Perhaps I am missing something?
    Nov 2003
    Massachusetts
    The other end of the cable is an OBD connector, the only difference is that this is used with specialized software rather than "general" OBD, I"m trying to figure out if the cable is non-standard too.
    When you connect and PBC cable to the PC does it just act as a serial cable with a regular COM port interface or are there special drivers etc to interpret the signal, or is that all in software?
    Thanks, Chris.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    From all of my research, there is probably not any speciallized drivers for the cable, its all handled by the software. And digimotojoel seems to be right. That cable looks a little big to be an ordinary serial cable.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Jun 2006
    I have that exact card. It has 20 pins. Does anyone know where to get one?
  1. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  2. Replacing connector in Lilliput
    By Chairboy in forum LCD/Display
    Last Post: 05-04-2005, 11:31 AM
  3. does anyone know where i can get a pcmcia card with usb and ethernet?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-27-2004, 06:01 PM
  4. OBD connector on 2004 Subaru STi.
    By LESLIEx317537 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2004, 07:10 PM
  5. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 05:16 AM
