Results 1 to 10 of 10
Thread: SRS light is ON
    Constant Bitrate i3igmind's Avatar
    Mar 2005
    Unhappy SRS light is ON
    Hi guys,
    After my accident and after my airbags deployed, my SRS light is ON. is there's a way i can turn it Off.
    1-how can i reset the computer?
    2- will i be able to reset it even thu i don't have the new airbags installed yet?
    please help
    thanx in advance
    HOnda Accord '94
    Zac
    Zac is offline
    Feb 2004
    VA
    best bet is to remove that light from the dash...
    Jul 2005
    Rosemount, MN
    We have a tool available that we sell that does this specific task, but costs around $1,000 ~ it's a killer (it works with many cars). Unless you are someone who performs these tasks regularly... there might be something specifically for your car that would allow you to do it (much cheaper).
    May 2005
    Woodstock, GA
    resetting the computer wont do jack. you have to replace the bags an often replace the air bag control module after a wreck. If you dont care about the air bags (I dont) you are better off yanking the entire system, including arbag computer.
    In many cars, simply yanking the bulb will have the air bag computer beeping or buzzing at you all the time
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Feb 2005
    Madison, WI USA
    When I had a BMW E36, I mucked with the passengers side airbag without removing the battery first and caused the SRS light to come on. The tool to reset the light cost me about $150, I used it once, and sold it. The tool itself was specific to a certain model range of BMW, and wouldnt have worked for other cars. You may be able to find one like that for your car, dunno. At the time, I was told it would cost $100+ to reset it at a shop due to the fact that they insisted on doing a bunch of diagnostic stuff before resetting it.
    Sep 2005
    I have a 5th gen accord too and my air bags were deployed too, I got so sick of staring at that srs light for years so I finally ripped out the gauge cluster and pulled the bulb out completely.
    Apr 2005
    Dublin, Ireland
    You shouldjust be able to briidge the circut where your airbag should be with the correct resister for your car and this should fool the system into thinking the airbag is installed. Or take the bulb out, did this in a 106 Peugeot with the resister,,
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    I have a 6th gen accord. Not sure about the 5th, but there is a plug called the MES connector. You use this and a speaker wire to short it in some wierd combination (similar to a ps2 game) this is how you reset the SRS light in my car. Hope this helps. Not sure if this works after airbags have been deployed.
    PC Components:
    My work log
    Variable Bitrate numbers's Avatar
    May 2005
    Forget about the expensive tools. Resetting the system is easy for your accord. Use google to find a how-to. You will need to replace the airbags first, though. Be careful working with srs stuff. It can be very dangerous. People have been killed by airbags deploying unexpectedly, and if you don't know what you are doing it is very easy to make one deploy unexpectedly.
    Mar 2003
    Gainesville, FL
    well now you have a good reason to fiberglass the dash and put on an aftermarket racing wheel
    2003 Mazda Protege5
    Molded Xenarc touch Screen
    Via M10000, seagate 40gb, 16x laptop dvd, RS gps
    EDAC 55w dc/dc
    homebrew shutdown controller
    2 power acoustik 10 FUBR's, A1800DB mono amp, AH600 to power mids and highs, pioneer speakers
  1. Looking for strong & cool bench light
    By kingtut in forum Off Topic
    Last Post: 10-26-2011, 09:27 PM
  2. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  3. BU-303 Dim Light????
    By KingsDude in forum GPS
    Last Post: 02-12-2005, 10:23 PM
  4. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 11:54 PM
  5. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
