11.5 i believe means 11 and a half= 11500 bits per second
115kbps= 115000 bits per second
i have the OBD-2 software and cable form this sight:
http://www.obd-2.com/
My problem:
i used to run this just fine on a laptop that had a seial connection built in. That laptop broke, got a newer onw that did not have a serial port on it, only USB's. I was told i needed to get this adapter:
http://www.keyspan.com/products/usb/USA19HS/
in order for it to work.
i had this one that i was using for other auto programs that worked just fine for them:
http://catalog.belkin.com/IWCatProdu...oduct_Id=91042
which is said to work up to a amx of 115 kbps.
the guy at OBD-2.com says i need the key span adapter becuase it supports a baud rate of 10.4kbps...
isn't 115 kbps the same as 11.5 kbps, which would be faster than 10.4 kbps, meaning the adapter i have should work?????????
am i all mixed up on baud rate and kbps definitions and what the numbers equal out to....????????
please help!!!!!??????????
thanx
10.4 kbps is a non-standard baud rate. This might be why they want you to use the keyspan adapter.
If It's Called Tourist Season, Why Can't We Hunt Them?
I Just Do What the Voices Inside My Head Tell Me to Do.
The Definition of an Upgrade: Take old bugs out, put new ones in.
Texas DOS: Y'all reckon? (Yep/Nope)
I have a belkin one that works great. But now I've updated my system to one that has a serial connection. Let me know if you want to buy it.Originally Posted by KB5WID
