Results 1 to 3 of 3
Thread: Airbag Codes
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Warrensburg, MO
    Airbag Codes
    Pretty sure I have my answer, but it doesn't hurt to ask... in case I missed it.
    Is there any OBD software out there that will use my ELM based OBDDIAGNOSTICS.com tool to diagnose an illuminated airbag light in my '03 Ford Escape?
    Thanks in advance.
    Rob
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    May 2005
    St. Thomas, USVI
    I am getting the same problem with my 02 escape the airbag light come one, sad to say that my scape just went out of warranty. Dont want to go back to the dealer, they charge $90 just to look at the problem. %@$!ing robbers.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    This happened to me when working in the car (disconnect the cable by accident) so I went on the internect and I found out that just making some steps (open door,closing doors, insert key in the inition 7 times yada yada yada) I was able to turn the light off.
    So my advice is just check the ford forums for something similar.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  1. Lilliput Programming Guide, More Reset Codes
    By Anointed in forum LCD/Display
    Last Post: 07-15-2011, 09:28 PM
  2. Can I switch off the passenger Airbag on a Opel/Vauxall Zafira via OBD-II
    By hgrutter in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-17-2010, 06:43 PM
  3. Via EPIA M 10000 Long Beep codes.
    By IntellaWorks in forum General Hardware Discussion
    Last Post: 06-12-2005, 12:55 PM
  4. kenwood codes
    By bigjez in forum LCD/Display
    Last Post: 09-10-2004, 08:24 AM
  5. Lost remote....anybody know some codes?
    By Tony S in forum LCD/Display
    Last Post: 03-11-2002, 12:53 PM
