hmm i doubt it...check the connector has the signal earth wire...i bet its missing.....
G'Day
Has anyone successfully talked to a 2000 Mitsubishi Pajero?
I've built an ELM 323 ISO adaptor, but can't get a response from the car.
From what I've seen, it should be ISO, but I'm having no luck.
I have double and triple checked my circuit, changed components, etc. I can talk to the ELM chip OK. The local auto trans guy has a SnapOn Tools scantool that talks to the car OK, but I'm trying to avoid spending $2000 for one of thoseHe doesn't have any info that can help.
Regards,
Paul.
does the ELM light up when plugged into the OBD port?
I can try it on mine later on...
Roy
2005 Range Rover 4.4
Yep, the ELM blinks out RS232 leds and only the CAR TX led. (and power led)
The connector has wires on both pins 4 and 5. I can't recall which one I've connected to, but I'm pretty sure they were both ground when I buzzed out the plug. Must sneak a look in the morning. Anything's worth trying.
