I you are looking for something to output directly to a tach, you could use the tach wire in your car (unless it doesn't have one, i think they all have to, don't they?). Or maybe you are looking to verify the existing tach vs. digital information?
To use OBDII you would have to have a device that would request the line of information for RPM, translate it, and they output it. Its going to come out of the OBDII port as a digital string, that would have to be converted to a screen, and then convert it back to a voltage level to use with the tach.
I don't know of any devices, but I think you would be better off with a hardware solution, not a computerized solution like this one. Unless you are looking for more info than that. Then any of the solutions posted here would work, depending on your car.
LinkBack URL
About LinkBacks
