Results 1 to 7 of 7
Thread: Relay to cut power to ElmScan?
    Aug 2005
    Toronto, ON, Canada
    Hi folks,
    I searched. Concerns over the 'always-on' LED on the ElmScan interface tend to draw responses that go a little something like this:
    This little light of mine,
    I'm going to let it shine!
    I guess that's fine for some folks, but I'm not really keen on knowingly introducing a constant power drain into my system, no matter how small. Has anyone ever tried to use a relay to cut power to the ElmScan when the car PC is off? I imagine this would involve intercepting the appropriate lead in the supplied cable, but I don't know enough about cable shielding and such to know if this would have any unintended consequences.
    Any insight would be appreciated.
    8^{D>
    FLAC evandude's Avatar
    Mar 2005
    Maine
    OBDII communication is done at a ridiculously slow data rate and does not involve any large power signals or anything like that, therefore wire shielding is not very important for it. however, it would probably be easiest to simply modify the board itself, by finding the power trace and cutting it, and soldering wires to each piece and then to the relay.
    or if you really want to be non-invasive, get a male and a female DB-9 connector from radio shack or somewhere, and build yourself a little short pass-through cable that can be plugged in between the elmscan board and the OBD cable, that passes all the wires straight through pin-for-pin except intercepts the power wire.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Aug 2005
    Toronto, ON, Canada
    Say, that's a good idea! Non-invasive is good.
    Thanks for the speedy response!
    8^{D>
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    I couldn't see the draw close to what an alarm does. Digimoto wheres the current draw spec.
    Jul 2005
    Rosemount, MN
    Jul 2005
    Rosemount, MN
    I have another diagram of the board laying around here somewhere... I'll search for it today.
    Aug 2004
    I'm curious about this too. Are most people just leaving their ELM connected?
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  3. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 08:55 PM
  4. Controlling your power setup remotely
    By auto_robotics in forum Power Supplies
    Last Post: 10-08-2004, 08:05 AM
  5. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
