Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: obd compeditor?
  1. #11
    Newbie komodo9's Avatar
    Apr 2005
    Athens, GA
    I have an AVIC-N2, but didn't get that module.
  2. #12
    Newbie raghavghei's Avatar
    Oct 2005
    Harrison,NY
    first of all i would say f u cuz u can afored dat lol
    and second you have to buy it serprate
    and third
    (Note: Not compatible with Pioneer Navigation Systems, such as AVIC-N2, AVIC-D1 or AVIC-N1)
  3. #13
    Aug 2004
    It receives it's inputs from GPS for things like speed, altitude,and such and can compute g's from inside the unit... im guessing it has a tach input to wire up but i doubt it's wired through obd cuz of vehicle incapability... (your avic's can do most of this stuff just not "diagnostic oriented"
  4. #14
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    $250 range on ebay......meh....not worth it....just a fancy gps speedo
    PC Components:
    My work log
  5. #15
    Aug 2005
    I have one... its amazing... The way it works is that the unit has a gyro inside it, and it gets its feed from the VSS and the battery power.
    So, once you calibrate the RPM, and the GPS does it learning, you are on your way.
    the display is amazing, specially the info you get from the Gyro like Slope angles, G forces, etc etc...
    I like it...
  6. #16
    Jan 2005
    I second the thought....someone PLEASE hack those screens.....
    They are soooo purdy
  7. #17
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    You can get Accelerometers pretty cheap. I've got a Memsic waiting to go into the car, paid around $29. There's better ones, but still pretty cheap in comparison.
  8. #18
    Low Bitrate jnafpas's Avatar
    Feb 2006
    Greece near Delphi
    Hmmmm someone said 19euros are to much for my application....
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    bumpity bump bump - anyone else with this unit?
    Jan Bennett
  10. #20
    Apr 2009
    any update on this? wondering if anyone's made this into a pc app or centrafuse plugin?
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  3. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 03:47 PM
  4. ? Potential damage to Carputer if dealer connects OBD device ?
    By SAScooby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-08-2004, 01:56 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
