Results 1 to 2 of 2
Thread: OBDII read and programming ECU
    Newbie johnwrx's Avatar
    May 2005
    Switzerland
    Good Morning to all
    I've read (if i've understand good) in the forum that with the ecu explorer and with the Openport 1.2 i can read & modificate parameters from the
    ecu of my Subaru WRX 2001/2002.
    It's something like ecutek?
    Can i do some programming (with help) if i change injector,fuelpump and turbo?
    Are there availabile maps for this system?
    Thank You all
    http://www.bluebullet.ch.vu
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Keep up to date on the progress of ecuExplorer on the Tari forum. Currently the program can read and log ecu parameters. It can also adjust your idle speed and timing. Calvin's goal is to make it eventually be able to reprogram the ecu, like ecutek.
  1. Lilliput Programming Guide, More Reset Codes
    By Anointed in forum LCD/Display
    Last Post: 07-15-2011, 09:28 PM
  2. Replies: 103
    Last Post: 02-07-2005, 11:56 AM
  3. help with programming languages
    By CornToeGoblin in forum Software & Software Development
    Last Post: 12-31-2004, 08:29 PM
  4. Media Engine Suggestions - Read!
    By infinitifanatik in forum Media Engine
    Last Post: 10-08-2004, 10:00 PM
  5. C++: GUI Programming with >NET Framework
    By [iG] in forum Software & Software Development
    Last Post: 05-24-2004, 07:57 PM
