Results 1 to 4 of 4
Thread: OBDii on non-US cars
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    I got confused when somebody on aussie magna forums told me that aus magnas don't have obdii. I wanted to make sure if obdii is only available on non-US cars. I have a Middle East specs 2002 Mitsubishi Magna.
    I was just about to order the digimoto package when i was told that the port that i see under the steering column looks like obdii but doesn't stream data in obdii format. Can u please help me. Does my car support obdii.
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    read the info in the table at the bottom of the page, then have a look at your connector in the car:
    http://www.digimoto.com/which_of_the_three_obd.htm
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Sharjah, Emirates
    I was told that having the port doesn't mean having obdii supported!!
    I had a look at the pin assignment on my odbii port... it matches the ISO type interface (pins 4,5,7,16...). DOES THIS MEAN I HAVE ODBii. can somebody with a non-US car, preferablly Middle East (gulf specs), confirm it.
    I was planning on ordering 3 packages but now i'm not sure. I live in dubai, and paying USD 350 for internationally shipping some chips and cables for hanging on my room wall isn't a pleasant idea.
    Edit: I just noticed u from Aus. Do your cars have obdii???
    I also have the same pin assignments (for ISO) in the Toyota Avalon, I plan to buy a kit some time down the track and find out if it works, but I have a feeling that it wont. However OBD is currently low on my list of things to do, gotta get a carputer running first! Thankfully today was my last exam (french!) and I have holidays untill March next year, so I should be able to get something together soon.
    [edit] Dubai? I've got cousins from there, in fact my uncle is over there
    Fox Mulder
    2004 Toyota MR2
  1. Able to get voltage from OBDII?
    By aoLhaTer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-18-2007, 10:26 PM
  2. OBDII Diagnostic Solution for $64 (+shipping)
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-11-2007, 07:54 PM
  3. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
  4. OBDII, GPRS, and car control
    By CarBaron in forum Hardware Development
    Last Post: 04-04-2005, 10:25 PM
  5. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 09:58 AM
