Results 1 to 10 of 15
Thread: Car Won't Start when OBDII connected?
    Spring Hill, Florida
    Does anyone have this problem? Mind you the computer has not yet been installed in the car, but I was in the process of running wires and so I connected the OBDII diagnostic tool and then the car would not start? This is on a 2005 Impala. Any ideas? If it had been connected to the carputer, do you think it would have started?
    2005 Black Chevy Impala
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Oh that's not good. It should still start even without the PC connected or on. What diagnostic tool are you using?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    What happens if the car is already started and you plug the diagnostic tool in?
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    If your using the br-3 the software says that you turn the car on then plug the device in. Some cars wont start while the BR-3 is connected.
    Quote Originally Posted by Sonicxtacy02
    That is the one I am using...if I plug it in while the car is running, it will work fine until the next time I start the car (won't start). Anyone know of a solution to this?
    Edit: (other than the obvious)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Shelbrain
    Hack the cable , put a switch in.
    or put a relay in so the the cable is only connected when the IG is on. (might have to put a delay on this as well)
    Woodbridge, VA
    Blog Entries
    55
    yea i added a switch. Just strip the wire cover down.. clip the red wire and add a switch in the middle
    Mar 2004
    Florence Yall, BFKY
    If it's on serial you should be able to control it with the DTR line. With a transistor and relay or something. You would just need to make sure the software isn't running when you start the car, which most of the time won't be the case.
    Jul 2004
    I have the 2003 Impala, and there is no problem with starting the car with the ODBII connector. Actually, I just tried starting it with the connector not attached to the computer. Started fine....
    Dwaine
    2003 Black Impala
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Curiosity
    Care to put that so it would make sense to a NEWB in electronics
  1. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  2. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
  3. Replies: 2
    Last Post: 01-26-2002, 05:53 PM
  4. Avoiding re-boot during car start
    By dos4who? in forum Power Supplies
    Last Post: 10-29-2001, 05:41 PM
  5. System Restarts whenever I start my car
    By Blue Falcon in forum Power Supplies
    Last Post: 06-25-2001, 06:15 PM
