Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
Thread: Nissan computer interface system
  1. #21
    Mar 2006
    damn bump bump
  2. #22
    Mar 2006
    bumo
  3. #23
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    try searching google and the MP3 archives instead of just bumping and waiting for someone else to do the hard work for you! Noobs
  4. #24
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    bump :P
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
  5. #25
    Aug 2004
    On the edge!
    Were are all the old guys to flame the n00bies when you need them
    Come on fellas, don't be lazy, use the search button
    PMSL developments or Blatz might be the places to try first
  6. #26
    Dec 2005
    ECUTalk v1.2 - http://www.ecutalk.com/
    Combined Standard and Pocket PC versions into the single unified executable (single .exe also), based off the last Pocket PC release.
    Added auto connect back in - it will connect on the given com port, select the sensors, and view gauges fullscreen on startup (after its set up).
    Added in injector duty cycle % sensors, and added MPH and degrees F sensors (for speed/temp).
    Left: Running on PC/Laptop
    Right: Running on Pocket PC
    More screenshots: http://www.ecutalk.com/screenshots.aspx
    For your carpc's, the gauges will rearrange to whatever size/aspect ratio that takes up the most realestate on your screen. eg it might look something like this, but without the black space top/below (given a widescreen).
  7. #27
    Mar 2006
    so will the ecu talk work with obdII-32bit cars????
  8. #28
    Dec 2005
    unfortunately not (unfortunately theres no pre-obd2 section on here). think theres plenty of other obd2 software out there?
  9. #29
    Jun 2005
    Might be off topic
    anyone using datascan software and driving an altima or 240SX? I need the data log file from you to compare mine.
  10. #30
    Apr 2002
    How many of you have tried the Nissan Data Scan Software with blaZt Consult interface? After looking through all these links it sounds like perhaps the way to go, although I'm not sure anybody has tried it with a VG33 1996-1999 US R50 Pathfinder or Infiniti QX4.
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. Troubleshooters! Computer turns off randomly and wont turn on, need help
    By phatbimmer in forum General MP3Car Discussion
    Last Post: 06-05-2005, 06:09 PM
  3. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 04:36 PM
  4. ideq computer system???
    By daworkz in forum General Hardware Discussion
    Last Post: 10-22-2004, 04:33 PM
  5. Display with buttons that interface with computer?
    By ryanjg11 in forum LCD/Display
    Last Post: 12-20-2001, 07:38 PM
