Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Nissan computer interface system
  1. #41
    Newbie v1per's Avatar
    Dec 2006
    Salisbury, NC
    I really wish I had modification capabilities with OBD-II but I guess I have to do it the old fashioned way, with new exhaust, intake, headers, underdrive pulley, etc.
    Max Messinger
    Computer Expert
    Car Newbie
    2000 Maxima CarPC Progress: 99%--Basic computer fully installed, full stereo overhaul planned for the future
  2. #42
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    The gauges don't resize when embedded in Centrafuse
    Could you make it so we can specify the window size by pixels in a cfg file or an .ini file, the problem with Centrafuse is that it has two viewing mode for apps, the easy way to explane it is fullscreen app, or app with music info & buttons added.
    When I get my hardware sorted out I'll do some screenies.
  3. #43
    Dec 2005
    yeh if u can do a screenshot thatd be good, im working on the next version over next couple of weeks so if u can show me what u mean by then i should be able to fix it up.
    the default behaviour is full screen will use the bounds of the primary screen for the full screen mode. (ie x, y, width, height). so i can probably set it up to read in a custom x/y/width/height values, or to simply use the bounds that the window is currently set to for full screen (which i assume is what you need for centrafuse, in that u dont want fullscreen window size/position to be any different from the non-fullscreen one?)
  4. #44
    Jan 2007
    Hey guys, I see a lot of threads for Nissan, But non for Nissan Sunny. Does somebody have an idea where to find this OBD-II connector in nissan sunny.
    Forgive for any stupid question - Just Born Newbieeee
  5. #45
    Dec 2005
    this thread isnt about obd-ii stuff, its about consult 1, the pre-obd2 diagnostic protocol. either way, you often find the connector near the fuse box, or around drivers knee area
  6. #46
    Aug 2004
    On the edge!
    making it fill out to the available size is what I'd like, whatever size that might be, can it not just scale up to the size it has available, rather than cutting the gauges off. Not able to get pics off my phone with this laptop, and my PC hasn't been unmpacked yet since the move!
  7. #47
    Dec 2005
    ive put an option in the next version to only use the "working area" rather than entire screen bounds.
    for example, on a normal computer, this means the whole screen except the taskbar (ie the size a normal window would maximise to). if windows behave the same way inside centrafuse, then this might work for it.
  8. #48
    Aug 2004
    On the edge!
    sounds good to me
    Cheers fella
  9. #49
  10. #50
    Aug 2004
    On the edge!
    Nice one fella, been waiting for the next edition for ages
    @ Newkleer:
    You should start a new thread about this with a more apt tittle
    PS. there are definate improvements with 1.3 with regards to the ability to change the gauge colours and especially the fuel economy thingy, but the screen fill size is still playing up
    I wish I was able to post you a screenie but right at the moment, mid moving house, I haven't got the hardware available to do it.
    It definately behaves differently when standalone (in which case it tried to fit all the dials in the PPC sized window, but when embedded in CF it still tries to display dials beyond the available app space.
    And how about sussing out some calcs to also get mpg worked out for us who still believe in Engilsh units
    My brain doesn't work in km/h and litres... I need UK gallons and good old miles per hour
    Another function which has suddenly struck me as essential is way to decide the order of the dials because for them to be useable when driving you need to be able to look straight at the dial you're interested in rather than having to stare at the LCD looking for what you want to see.
    I appreciate your efforts, and would love to help you but my programming skills are lacking to say the least Keep up the good work Mr.
    EDIT: Hang on a minute, first time I downloaded the PPC version And I may be confusing some of the problems that the PPC one produced when run on a PC, and the car is in the garage now, 150ft away and its -2C outside So we will have to wait till tomorrow to be sure
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 09:51 AM
  2. Troubleshooters! Computer turns off randomly and wont turn on, need help
    By phatbimmer in forum General MP3Car Discussion
    Last Post: 06-05-2005, 05:09 PM
  3. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 03:36 PM
  4. ideq computer system???
    By daworkz in forum General Hardware Discussion
    Last Post: 10-22-2004, 03:33 PM
  5. Display with buttons that interface with computer?
    By ryanjg11 in forum LCD/Display
    Last Post: 12-20-2001, 06:38 PM
