Did you get anywhere wit the T4 diagnostics?
I met one guy who managed to tap directly into the bus going to the SLABS ECU. He was able to read codes and set them. He hasn't wrapped up the hardware or software enough to build a generic user interface on top of it though. His ultimate plans are to release it as open source software, although I don't know what his timeframe looks like.
I don't know anything more. He just dropped me a note because I was running a small project related to this for a while. I gave up and am buying a '65 Series IIa.![]()
Why is it hard to believe? The Rovacomm light goes for about $1500 which given the limited market size is pretty reasonable. Granted, I'm to cheap to pay that much, but if I owned a shop I'd drop that amount in a heartbeat. Compared to rent, insurance, and payroll, it would be a drop in the bucket.
Rovacom Lite doesn't exist anymore - prices are very competitive now, take a look at our web-site for details: http://www.ukobd.co.uk/landrover.asp
Gareth
UKOBD
Your product is limited to a single vehicle and it is going for $1365.47 + shipping.
That is less reasonable than the Rovacomm Lite. At least with the other system I could use it to diagnose more than one Rover (mine or my club members).
Hi,
I think you need to look at the site in more detail:
a) Rovacom Lite did not cover all ECU's this does, therefore the price
b) Hardware and software on a per ECU basis can now be purchased for multiple vehicle, you only need to buy as you need
Also Rovacom Lite is an obsolete product, the Faultmate is its replacement - brought out to be more competitive.
Hope that this helps.
Gareth
I've been putting some info together and developing an open source project of my own, called "Alt4", as in Alternative T4. It's early-days yet, but I have had some success communicating with Range Rover P38 ECUs.
Details are on my site:
http://www.swiftcomm.co.uk/alt4/
If anyone would like to have any input into the project, then please feel free to get in touch.
Cheers,
Chrisall.
That's misinformation. The 3 amigos can be caused by all sorts of things and regularly are caused by a variety of things. Shuttle Valve, bad hub (that fouls the wheel speed sensor), bad wheel speed sensor, bad connector between the wheel speed sensor and the primary wire going to the SLABS ECU, bad modulator, etc. If you get the 3 amigos, have the code pulled and go from there.
T4 Land Rover Mobile plus nice diagnostic tool for land rover, T4 Mobile Plus has been designed with portability and ease of use foremost. T4 Mobile Plus has been specifically optimised for use as a "Road Test" tool using standard T4 diagnostic software. T4 Mobile Plus has been designed as a fully expandable diagnostic tool, which will support full integration with the expanding T4 Product Platform. if anyone is interested in it, pm me.
