Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Does a Lamborghini Diablo have OBD ?
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Yip, a friend with a Diablo wants to put a car pc in for ecu access and information, first up its a 2000 Diablo, do these cars have OBD ? is there any software out there for them ?
    I found the Ecus ? 2 of them, one for each bank of cylinders ! but couldnt find an OBD port.....help !
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    All cars after '96 are OBD compliant... so yes it should have a OBD port somewhere...
    Feb 2004
    so where is it .....?
    any clues ?
    Aug 2004
    Pearland
    underneath the dash i would expect... all my cars are underneath the dash closest to the drivers side door...
    Feb 2004
    I dug around, didnt find anything, I was beggining to wonder if its behind a hide away panel ? like some Renaults ?
    it also aint a thing of beauty under the dash thats for sure !!!
    I found the Ecus and tried to trace backwards but no luck, do you think the connector is the same ?
    Aug 2004
    Pearland
    i guess if you dont just see it.. it will be hidden away behind a panel.. contacting your local dealership and asking them might be the way to go...
    and yes the OBD connector is a standard connector....
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    OBD is a U.S. standard. All U.S. cars have it, but if it's not a U.S. car or U.S. import, it may not have it.
    Want to:
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    + it was built in italy so even if it was supposed ot have one they probably forgot or thought the guy put it in or designed it in for that matter!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If the car is in South Africa, and bought there, it may not have such a port.
    What is the South African requirements as far as OBD-II compliance?
    Feb 2004
    hmmm OBD in South Africa
    well we are still in the dark ages here
    Leaded fuel was only withdrawn as of the first of January 2006
    there is no emissions testing laws at all in South Africa
    OBD ports are for some dealers and carpc users, the general populace has zero idea of there existence and yes the car is here, the local lambo dealers will only disclose its whereabouts for a fee....so I guess google is still my friend despite turning a blank up on this, found some germans that remap via the obd port but they dont say where the port is.....
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  3. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  4. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 03:47 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
