Results 1 to 6 of 6
Thread: OBD2 protocols??
    Jan 2006
    OBD2 protocols??
    Hi, new here. I was wondering if anyone could help. I have recently been exploring the world of obd diagnostics and have gotten use to VAG diagnostics. But recently i decided i would want to diagnose my own car. 2000 peugeot 306 GTI-6. It has the same engine and wiring as the CITROEN xsara VTS
    I recently bought an elm323 obd2 connector for use with digimoto! Having tried the VAG obd2 cable with my car with no luck i thought the elm323 connector should work as my car is listed for the ISO protocol. I connected it up and REd light came on meaning there was power going to connector then started software and turned ignition on. The software recognised the cable and connected, but it is failing to connect to the CAR. It does not recieve any real time data or recieve fault codes.
    Could this be to the BAUD rate?? as i presume its 9600 standard? Also had anyone successfully connected their gti-6/vts with obd2. I have also tried genric code readers with no luck. It seems that only PEUGEOT dealer can cater for this diagnostics???
    thanks in advance
    M
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    My Subaru's ISO odb baud rate is 4800. Try setting to that.
    Jan 2006
    Quote Originally Posted by wi77iam
    How do you set the baud rate with digimoto??
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    I'd suggest troubleshooting with hyperterminal first. Make a plain serial connection with the appropriate comport set at 9600 baud, with no parity and no handshaking and see if your interface responds to commands as described in the ELM323 datasheet.
    Hope this helps.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    It seems that Peugeot had got his own ODB protocol until years 2000-2001 (for gazoline and petrol engine).
    Only cars after 2001 have a standard ODBII protocol...To be confirmed.
    Oct 2005
    Wow coucouillu, I'm glad I saw this post. Both because I now know my 2001 306 HDi should be fully compliant, and also because that the heater 'overhang' in the 306 doesn't get in the way of a flip out screen.
    Thanks a million!!
  1. Technical data from obd2
    By Stephan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-20-2011, 02:10 PM
  2. Help: OBD2 Extension Cable?
    By LarryMZ3 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-19-2008, 06:36 PM
  3. OBD2 Support in CF 1.4 ?
    By tHaHooL in forum Centrafuse
    Last Post: 08-05-2005, 11:15 AM
  4. any interest for a cheap obd2 reader?
    By infinkc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-23-2005, 03:59 PM
  5. obd2 interface
    By Rita in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-09-2005, 03:57 AM
