Try this link http://www.qcontinuum.org/obdgauge/index.htm
I have been looking around for an OBD scan tool for my iPaq and I realized it looks like I have the T16-009 interface that I use for my laptop OBD-2 program. As I read on the Multiplex website, it says in the FAQ section that it does not come with software, you must write your own. Is there an easy way to write software? Now that I know what tool I have, it seems useless for me to go out and buy another when all I need is the software. The OBD Gauge program won't work with it. Is there any software already written for the Multiplex Engineering T16-009?
Dan
OBD Gauge states on the website "Multiplex offers the T16-009 which also supports the CAN protocol, but is not yet supported by OBD Gauge. Support for the T16-009 will be added in a future version." So atleast for a little while I can't use OBD Gauge, which seems to be really well setup. But I am out of luck with that for atleast a little while.
hi, i also have a multiplex engineering interface, but i wanted to use it with my PC, is there any software availabel that works with this interface? and not the pc version of the one that makes the pocket version... a mean some software with all the gauges, not graphs...
Try www.obd-2.com. Their software has everything and it's free. It is a PC version and easy to use once you learn it.
for what i could see it does not support non-US cars... i have a Renault Megane Scenic, i aready have located the plug and have it worknig with my pocket pc, but i would like to have it runing with the carputer i'm building...
any software that has all the gauges? i'm only interestes in showing the rpm, speed, throtle, anything that can be seen as a gauge
hey, anyone has used the OBD Gauge? i need some help!!! it doesn't work, it stays on: "Initializing" and does nothing... please help
hellooooooooo?????? any MULTIPLEX ENGINEERING INTERFACE COMPATIBLE SOFTWARE???
Our PCMSCAN software fully supports the Multiplex Engineering T16 interface. Unfortunately, we do not support handheld devices at this time.Originally Posted by novolo
Brian @ Palmer Performance Engineering, Inc.
http://www.palmerperformance.com
THANK YOUUUUUUUUU![]()
i've been looking everywhere for a multimplex compatible software and the onlyone i found was obd gauge for pocket pc, and it didn't even work!
thanks man! can't wait to test it with the pc
