Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: OBD connector location for Ford Escort??
  1. #11
    Apr 2009
    1999 ford excort OBD II help??
    Hi, I am working on my sisters 99 ford escort and I am trying to jump it into diagnostic mode so I can read the trouble codes through the check engine light
    and yes, it's OBD II which is located on the drivers side under the dash. Iwas looking at a haynes manual to found out how to jump it into diagnostic mode but, the manual only shows how to do this on 1.8L and 1.8L engines not 2.0L engines; I know it can be done because, I did it once before but, I forgot which pins to jump? I hope someone can help me out?? Thank you for your time in reading this ^_^
  2. #12
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by spud_rocket View Post
    My Autodata book tells me that "scan tool is required to read trouble codes". Were you jumping pins on the OBD-2 diagnostic connector?
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  3. #13
    May 2009
    To wywywywy and others:
    Ford Escort (and Mondeo and others Fords) which has standard OBD connector has OBD diagnostic. But some has OBDI and others OBDII.
    If your car has EEC IV (OBDI) computer of enjection, you can not use "standard" Ford PWM cable. It is only for EEC V usable.
    But, I have almost done diagnostic for EEC IV with OBD connector.
    You can take a look at
    https://www.scantool.net/forum/index.php?topic=995.15
    and http://www.fordfans.cz/phpBB2/viewto...=asc&start=540
    and http://www.fordfans.cz/phpBB2/viewto...=asc&start=560
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  2. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 07:05 PM
  3. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 02:47 PM
  4. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 10:01 PM
  5. WTB: MkII Escort / FS: Mk5 Escort / FS: Mitsubishi Carisma
    By Confused in forum Classified Archive
    Last Post: 08-07-2003, 01:45 PM
