Results 1 to 8 of 8
Thread: obd-ii y-cable?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    obd-ii y-cable?
    does anyone know if there is an obd-ii y-cable available? I have to plug two things into my obd-ii plug and I dont want to have to constantly switch them out.
    the two pieces that need to be plugged in are a scan tool and a window valet (adds certain functions that didnt come with the car)
    thanks
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    See http://www.drewtech.com/products/cables.html for a dual J1962 breakout box. If that's too bulky you may need to buy the connectors and hack together a wiring harness yourself.
    In some situations the network will freak out when two modules think that they have the same address. Hopefully the window valet and scantool play together nicely.
    Dec 2004
    Los Angeles Ca
    wow...thats kind of expensive! I ended up asking 'top down tech' the maker of the window valet and they are going to make me a piggy back module. i'll have to splice in the power and required data lines but it should all work. if they dont play nice i'll just have a relay switch between the two when the computer is off. thanks for the suggestions though
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Oct 2005
    Livonia, MI
    Yeah the breakout box gets pricey because there's a ton of wiring for the 16 banana jacks, two female connectors, and one male connector. The one I suggested is more useful as an engineering tool so you can "sniff" the bus and reverse engineer the commands. If you can get the piggybox box for $25, go for it!
    Newbie millc5's Avatar
    Nov 2005
    CA
    Quote Originally Posted by scott_fx
    wow...thats kind of expensive! I ended up asking 'top down tech' the maker of the window valet and they are going to make me a piggy back module for $25. i'll have to splice in the power and required data lines but it should all work. if they dont play nice i'll just have a relay switch between the two when the computer is off. thanks for the suggestions though
    Scott,
    I need this as well! The window valet is the only reason I have not hooked up a OBD-II scanner to my carpc. Who did you talk too? Did they say it would work without any issues?
    Thanks,
    Rick
    Dec 2004
    Los Angeles Ca
    hey rick,
    i just sent an email to thier general email alias that was on thier contact page.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2005
    CA
    hey rick,
    Thanks! I will contact them.
    By the way have you tried the Accessory valet they sell for RAP to your CarPC setup? It would be sweet to turn the PC on and off via keyfob, or leave it running until the door is opened after shutting the car off..
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Sorry to be resurrecting an old thread; just thought I'd mention that you can buy an OBD-II Y cable here:
    http://www.obd2cables.com/products/o...cable-1ft.html
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 01:08 PM
  2. Looking for Non ELM software for OBD II
    By Refael Azi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 10:32 AM
  3. 2.5" IDE cable question...
    By SamDude in forum General Hardware Discussion
    Last Post: 01-13-2006, 04:49 PM
  4. OBD II connector uk?
    By Jamez_Warner in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2004, 04:16 AM
