Results 21 to 30 of 33
Thread: Doing more with OBD
  1. #21
    Oct 2006
    Connecting a PIC to the ELM327 is fine with me... I guess I just need to sit down and do a little research on how to interface the two together in a standalone unit.
    Thanks again for all the help!
    -Chris
  2. #22
    May 2006
    Seattleish, WA
    Quote Originally Posted by srracer View Post
    Are you looking to code in assembly or C?
    Here's a GREAT set of tutorials on PIC programming and interfacing:
    http://www.winpicprog.co.uk/pic_tutorial.htm
    #7 is all about interfacing with RS-232:
    http://www.winpicprog.co.uk/pic_tutorial7.htm
    :: Mark
  3. #23
    Oct 2006
    I know C - Assembly I'd have to learn. But I'd love to be able to build this out of parts that are dirt cheap - which would lean towards using an cheap off the shelf microprocesser and force me to learn assembly I suppose.
    -Chris
  4. #24
    May 2006
    Seattleish, WA
    Not really, there are free PIC cross-compilers (compilers that generate code for a platform other than what you're running on) that run on Windows.
    If you've never done a PIC/stamp project, you're gonna have about $100 in start-up costs no matter what. The expense of any platform like this will look like:
    • PIC/stamp cost
    • PIC blaster or i2c interface
    • external parts (resistors, caps, RS232 chip)
    • breadboard and wires (HIGHLY recommended versus blowing through perf board)
    • _time_ (this is a big one, it may take you longer than you think to get the dev environment running)
    Don't discount eBay for stuff like the PIC programmer. You won't need anything fancy for what you're looking at doing.
    :: Mark
  5. #25
    VENDOR - OBDPros
    Mar 2006
    I have posted a method to unlock doors on newer GM vehicles, check out
    http://obdpros.com/yabb/YaBB.pl?num=1162750290/0
    Hopefully people find similar messages on other vehicles and we can build up a database.
    Paul
    www.obdpros.com
  6. #26
    Oct 2006
    I got my OBDpro and have figured out how to make some interesting changes to the radio & amplifier in my CTS from the computer... I also have ordered an AVR microcontroller and some prototype components... This ought to be fun! I'll update the list if I make some good progress.
    Thanks for everybody's help!!
    -Chris
  7. #27
    VENDOR - OBDPros
    Mar 2006
    -Chris
    Hey Chris,
    Thats great work, don't be shy please tell us what commands you discovered so far
    Paul
  8. #28
    Nov 2006
    SC
    if only someone knew how to recode the idrive on the bmw thru obdII
  9. #29
  10. #30
    Jul 2004
    I have a 2003 Impala. I'm willing to test.
    Has anyone actually built a device with the cell module? I would love to build one and mate it to the odbii sensor.
    Dwaine
    2003 Black Impala
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  3. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 03:47 PM
  4. ? Potential damage to Carputer if dealer connects OBD device ?
    By SAScooby in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-08-2004, 01:56 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
