Results 1 to 3 of 3
Thread: Megasquirt meets the carpc
    Dec 2005
    Killeen, Tx ( Iraq)
    I dont know if anybody uses thier carpc to run aftermarket ems but I just had to go there. If you do please post screen shots of your ems software running in your car. Here is mine.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    You're not running DSMLink because you have a GS-T (instead of a GST/GSX) or because it's too damn expensive?
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Dec 2005
    Killeen, Tx ( Iraq)
    Quote Originally Posted by DJiK
    I have a rs-t and dsmlink wont work. Even if it did have a gst/x I think I would still run megasquirt. It gives you more to play with and is much less in cost. Also it is alot more flexable.
  1. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  2. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  3. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 09:56 PM
  4. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
