Results 1 to 2 of 2
Thread: Was there a solution found for non-ODB vehicles?
    Mar 2006
    Question Was there a solution found for non-ODB vehicles?
    On 12Jan2004, Confused posted this:
    Old car/engine, non ODB, how to get RPM/speed/temp/etc into carputer
    Was there ever a soultion that came about to use the carputer to monitor/replace the original gauges on a vintage/non-ODBI/II car?
    I searched and searched, but I could not locate anything for non-ODB vehicles. Maybe I am using the wrong search criteria, although I have tried everything that I could possibly think would be in a post covering the subject...
    Could someone please point me in the right direction?
    Mar 2005
    Well one way would be, and might be only way, is use a serial interferance w/ custom software. You may need to throw in a digital to analog converter. If you spedo is cable driven, your out of luck. A non-cable one would have a speed sensor somewhere that puts out a pulse that would have to be inputed via serial bus and custom software to convert the pulses to a speed.
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. OBDII Diagnostic Solution for $64 (+shipping)
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-11-2007, 07:54 PM
  3. a serious solution
    By sohaibma in forum Power Supplies
    Last Post: 04-06-2005, 03:44 PM
  4. Anti-Glare solution found?
    By pyros in forum LCD/Display
    Last Post: 08-31-2004, 02:41 PM
  5. Found display solution for epia M10000
    By Santa Cruz in forum General Hardware Discussion
    Last Post: 05-11-2004, 03:35 AM
