Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: OBD II Scan and BMW?
  1. #21
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    I thought that year would use the older 16 pin connector....type A i think. You can find pinouts for both connectors. here is the twenty pin: http://pinouts.ru/data/car_diag_pinout.shtml
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  2. #22
    Sep 2005
    Thanks ! youre probably right. I need to count the pins to be sure. Any link for the Type A connector?
  3. #23
    Apr 2006
    Quote Originally Posted by e30_droptop
    it's not that simple. before 1996 and obd2, obd1 existed and was no standard. Rememer most of the tools available in the net are for obd2.
    Your E30 does not support a lot of features (mostly the ones we the amateurs care about, like dyno i think).
    Although using the appropriate wirings and circuitrly and programs you may communicate with your e30. the only way i know to speak with a bmw pre 96 with obd1 is carsoft... ( i hope i am wrong)
    carsoft circuitry
    carsoft bmw
    at least this is what i read so far in the net.... i am not an expert...
    ps. in the next few days i am gonna try some custom circuitry for a 316 M40 OBD1 engine + carsoft. I'll let you know the result.
    the picture from carsoft's help
  4. #24
    Apr 2006
    also the Diagnostic sockets in E30 are of two types early and late.
    If yours has the pacman in the center is the latter, the 20 pin.
    the early's pinout is unknown to me. the pacmans pinout and the early and late sockets are
  5. #25
    FLAC chut's Avatar
    Jul 2003
    Excellent info, thanks for the help. I am probably gonna wire my own connector and will contact BMW about the proper wire ends in the diagnostic connector. Has anyone used another end that fits? The BMW part number is 61 13 1 376 191.
  6. #26
    Apr 2006
    BTW in the photo with the late socket and only in E30
    1. wire with no resistance (i don't the term for that in english, shortcircuit maybe?) the pins in red color with ignition key in OFF position.
    2. Turn the key to ON (without starting the engine) for 4 to 5 seconds max.
    Switch off the key and unwire the pins in diagnostic socket. This should erase the I_WANT_SERVICE indication/leds.
    source: www.bmwe30.com
  7. #27
    Jan 2006
    Cyprus
    Could anybody point me in the correct direction? I'd like to get an OBD cable, to hook it to my carputer but I have found 3 matches for obd cable on ebay. What's the correct one?
    Car is a 2001, BMW E46 320ci
    1:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
    2:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d..._BIN_Stores_IT
    3:
    Cheers!
  8. #28
    Jun 2006
    E-46 Daignostic socket
    Could you enlighten me as to the location of the diagnostic socket for a BMW E46? (2001 325). I can's seem to find it under the hood.
  9. #29
    FLAC chut's Avatar
    Jul 2003
    I don't know exactly where it is in your car, but most likely it is within sight while you are seated behind the steering wheel. Look around your center console, under the bottom side of your dash....its probably a plastic cap that slides out of the way. BTW....All...I got my cable to connect to the 20 pin socket and my laptop saw the connection immediately. I guess in my model car they just didn't connect to the ODDII port inside the cab.
    Who knew??
    Quote Originally Posted by Mern
  10. #30
    Jul 2001
    hijack - Man I wish i had an e30
  1. need a scan tool or interface for bmw 02'
    By rojobeamer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-21-2005, 08:03 PM
