Originally Posted by
OldSpark
But lets say for argument's sake that O2 sensors are fast enough and able to measure EVERY stroke (don't forget wasted strokes!), then you have pressure and temp to measure as well.
Do it by all means, I still reckon the flow else injection volume is the most accurate. Flow is best where as injection volume needs injector profile, but that can be a continuous function. O2 sensors also need to be continuous (which they had no hope of last I looked) plus the pressure/temp profile.
As you wrote, even 1/10th of a second is a mere 600RPM - assuming a 1/2 cycle for a one-cylinder engine is good enough for your economy readings, or one reading every 15 ignition strokes for a 6 cylinder doing 3,000RPM.
