Get that from the injector specs...
Decide whether you want a rectangular average (eg, width minus half ramp up&down time) or mapped; assumed pressure (eg 3 bar) or measured etc.
Squirt volume times injections (x cylinders) divide by distance.
Metric or imperial to your liking.
PS - I only ever dealt with low-Z injectors.... I never bothered with the voltage bullsh that hi-Z injectors allegedly require... (Where that was an issue, hi-Zs were replaced with low-Z's, else a regulated voltage rail was used.)
