Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 123
Thread: Calculating MPG from VSS and MAF from OBD2
  1. #101
    Raw Wave
    Nov 2009
    Get that from the injector specs...
    Decide whether you want a rectangular average (eg, width minus half ramp up&down time) or mapped; assumed pressure (eg 3 bar) or measured etc.
    Squirt volume times injections (x cylinders) divide by distance.
    Metric or imperial to your liking.
    PS - I only ever dealt with low-Z injectors.... I never bothered with the voltage bullsh that hi-Z injectors allegedly require... (Where that was an issue, hi-Zs were replaced with low-Z's, else a regulated voltage rail was used.)
  2. #102
    Newbie split63's Avatar
    Feb 2009
    Question MAF Accuracy
    MAF sensors produce results which factor in temperature, humidity, and altitude. They seemingly make the job of determining the Mass of Air flowing into the engine easy.
    However, I'm wondering how accurate or linear they are. For example, let say a known mass of air is passed through the MAF sensor. How accurate would the result be if the temperature was then varied from say 0F to 120F? Likewise with the humidity and pressure (Alt)?
    Any one have any data?
  3. #103
    Raw Wave
    Nov 2009
    According to you, they factor that in.....
    But MAFs are mass-flow, hence usually only measure flow & temperature.
    The temperature won't vary significantly through the MAF.
    Humidity (if measured), and pressure (altitude) are different sensors.
    Get linearity from the specific MAF specs.
  4. #104
    Mar 2011
    A confusing problem
    Quote Originally Posted by wi77iam View Post
    The software that came with the OBD reader I have, has some formulas for computing various things from the codes. One of which is instantaneous MPG, as follows:
    instantaneous Distance D = VSS * t/3600
    instantaneous Fuel F = 1 / (14.75 * 6.26) * MAF * t/60
    instantaneous MPG = D / F
    t is delta time.
    So other than the conversion constants being slightly different, I would say your formula looks good.
    Dear sir,
    I think the formulas you offered are really quite concise and smart.
    However, I am confused that how to obtain the constants 6.26 and 60?
    What are their units? It is not appeared and consistent with the formulas offered by maeliosa. I appreciate your kindly answer and help.
    SY Chen
  5. #105
    May 2011
    Thumbs up Yo Punks!
    YOu stupid yankies don't know how to calculate MPG? Ha, ha, ha!
    MPG = miles per gallon = miles/gallon
    (miles/hour)/(gallons/hours) = miles/gallon = miles per gallon = MPG
    It's ease
    so you need a speedometer, fuel flow meter and calculator, that'd be able to do only one operation///\\\
  6. #106
    Raw Wave
    Nov 2009
    The obvious stated by one without a clue. How refreshing. (Especially getting a speedo LOL!)
  7. #107
    Jun 2011
    Hi to all..
    I'm trying to create small application for calculating LPK, KPL etc.
    So, now I have found problem with calculation of MAF from MAP, RPM, IAT.
    The problem is in that in injector engines when you release at all acceleration pedal PCM will block fuel supply and LPK momentary must be 0. But in case of calculating MAF from MAP, RPM, IAT LPK momentary will never be 0. Someone solved that problem?
  8. #108
    Raw Wave
    Nov 2009
    I like the page 1 solution - use the injector pulse-width.
    How much are fuel-flow sensors? If they are (relatively) as cheap as photo-diodes & -resistors, I prefer that to certain other solutions (like using GPS for dimming; those $1 photo-components work in tunnels and during any weather or eclipse). ( )
  9. #109
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by OldSpark View Post
    Most if not all of the market is marine stuff, for calculating exact fuel usage on boats (to avoid running out of fuel on the water). They run in the $100-$300 per sensor range. I've yet to find anything capable of sufficiently high pressure and flammable fluids capable for any cheaper.
    RevFE
    My Shop
  10. #110
    Raw Wave
    Nov 2009
    Hmmm - I recall from under $100 (so I made my own with a conical seat and a spring and used the spring's varying inductance/impedance to indicate flow rate).
    But that was for older low pressure systems.
    Injection systems also suffer from their reticulation system - you'd have to have 2 sensors - subtract the return flow from the forward flow (hence doubling inaccuracy).
    AFAIK, most use injector pulse widths. It's usually reasonably accurate since the pressure is constant and pulse width can be read else monitored - just allow for open and close time (ie, half the flow during the open+close time, and the remaining time x flow).
    And that can be extended to all injectors when differing injection volumes occur.
