Modern cars circa '96 do run at stiochiometric as soon as possible...
Quote:
Originally Posted by
dreadknought
as many have posted already, the formulas given here are for stoichiometric fuel ratios. Unfortunately, modern cars don't run at stoichiometric fuel ratios. They run as lean as possible, just on the cusp of lean missing when cruising. They run rich anywhere from half-throttle to WOT. They automatically compensate for sub-standard fuels and fuel additives that affect octane.
My suggestion is, use the formula for calculating stoichiometric fuel consumption, but use the LTFT (Long Term Fuel Trim) to find what the vehicle is actually using. LTFT is given in +/- % (percentage). An example of the formula to use is
MPG = (14.7 * (1 + LTFT/100) * 6.17 * 454 * VSS * 0.621371) / (3600 * MAF / 100)
MPG = 710.7 * VSS / MAF * (1 + LTFT/100)
This formula uses the car's fuel trim value to compensate for the difference in actual AFR and stoichiometric AFR, however I'm not 100% sure that the LTFT value is % difference from stoichiometric. If anybody has any ideas as to how correct my thoughts are, please respond.
and as much as possible because this represents the ideal mixture of air/fuel that produces the exhaust gases best processed by the 3-way converters.
Under non-open loop operation (cold start, hard acceleration, closed throttle coast down) the controller can go open loop and then can feed teh engine nearly any air/fuel mixture it wants.
All fuel consumption calculations are going to be imprecise unless one knows the weight the gas being consumed to a precise value. Gas weight varies due to differences in blends that arise from octane differences, or gas targeted for a season or a region that has some botique blend requirement and temperature to name a few factors that I can think of. There could be more.
But fuel consumption based on air consumption is probably good enough for all but labs needs.
Sincerely,
MarcW.
