Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 117
Thread: Calculating MPG from VSS and MAF from OBD2
  1. #41
    Sep 2008
    Quote Originally Posted by jiggersplat View Post
    does anyone have and code or binaries they want to post that will work with an elm on windows?
    I can email you a zip of a cheesy 2005 VB.net program I wrote that will work for an ELM327 and read basic OBD PIDs. It doesnt do MPG though.
  2. #42
    Newbie split63's Avatar
    Feb 2009
    Volumetric efficiency varies with RPM, as noted by an earlier post. Its not just a inversely proportional relationship, as there are sympathetic harmonic effects in the intake and exhaust which can and do apply.
    I have gotten the impression that the PCM contains a table which has the VE as function of RPM. But I have never come across a means for accessing it.
    Regardless, I'm wondering if the instantaneous VE is reflected in the intake Manifold pressure (MAP). For example, let say @ 1000 RPM, the VE is 70% but drops to 65% at 2000 RPM. Is the MAP value different than it would be if the VE was a constant?
    Given that the previously defined equation for calculating MPG based on MAP, is it enough to make the VE a constant at, in this case, 70% and then rely on the MAP to factor in VE changes with RPM ?
  3. #43
    Newbie jyaron's Avatar
    Aug 2004
    So in a MAP based calculation:
    pseudoMAF= (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
    Therefore, if VE increases,.. pseudoMAF increases?
    I thought the engine sucks less fuel if it has higher volumetric efficiency?
  4. #44
    Sep 2008
    Not quite.
    I think you are thinking another type of efficiency, perhaps thermal. VE is the engine's ability to move air through the engine i.e. a ratio of displacement to air coming in. If it can move more air, it can move more fuel.
  5. #45
    CwF
    CwF is offline
    Jun 2008
    Denver(ish)
    Quote Originally Posted by malcom2073 View Post
    I'd say probably, as a diesel engine pushes more fuel for more power, rather than more air, and dosent try to obtain a stoimetric air/fuel ratio of 14.7:1.
    However, because your fuel usage is directly affected by your throttle position, perhaps there is a way to figure it out that way?
    I think the diesels simply sum the commanded fuel shots, or sum from a mapped table of cc's @ rpm @ tps.
    06 Silverado LBZ wants onboard everything...
  6. #46
    Feb 2009
    Quote Originally Posted by jyaron View Post
    VE refers to how completely the cylinder can be filled with each intake stroke. Because of the restrictive nature of the intake path and the inertia of the air/fuel mixture, the cylinder can not fill completely before it begins its up stroke. So if it only filled with 80% of the air that it could have, it has a VE of 80%
    The IMAP above is absolute. So if the engine can "suck" better, the IMAP would be less (more of a vacuum). So if we could adjust VE with a knob we might see that as VE increased, IMAP decreased. VE ^, IMAP V.
    Furthermore, with increased VE, the throttle need not be opened as much, as the same air/fuel is needed, so perhaps the IMAP would decrease. Or may be its the same
    VE is not a constant, it varies with RPM. Ignoring the potential harmonic effects, one would expect that as the RPM increases, the cylinders have less time to fill, hence the VE drops. As VE drops, IMAP would increase (less vacuum). But since RPM is increasing, there are more intake strokes per second to suck more air and hence IMAP may decrease.
    Hell, ultimately I'm not sure if IMAP provides the compensation for variations in VE. Hence my question.
    Has any come across a chart of VE versus IMAP. Though such a chart would likely be different for each engine design, a single chart would at least provide some insight into the relationship.
  7. #47
    Dec 2008
    good project. thanks for share
  8. #48
    Newbie lightner's Avatar
    Sep 2007
    La Jolla, CA
    Quote Originally Posted by split63 View Post
    Been there...done that. As it turns out, this is a very "doable" project if you happen to have an OBD-II compliant vehicle with a MAF sensor---plus MAP, IAT and RPM sensors (almost 100% of OBD-II vehicles have these latter three). The MAF sensor gives you air-flow directly. The other parameters can be used to get a value that is directly proportional to volumetric efficiency (VE)---using the methods I've discusses earlier in this thread. The MAF sensor's "air flow" reading allows you to solve for VE. Then you can plot VE vs. RPM.
    You will likely find that VE is in fact *not* a constant and does vary somewhat with RPM. And, depending upon the exact vehicle, the precise relationship between RPM and VE may be "complex", for all the reasons you discussed.
    However, if you just want long-term MPG, you will find that using a constant for VE likely gives you a number that is "good enough". Part of the reason for this is that during "normal driving" a vehicle's engine is operated in a relatively narrow range of RPMs, and therefore with a more or less constant VE.
    Best regards,
    Bruce D. Lightner
    lightner@lightner.net
    http://www.lightner.net/lightner/bruce/
  9. #49
    Jun 2009
    Available % of PIDs
    If as Bruce says:..." MAP, IAT and RPM sensors (almost 100% of OBD-II vehicles have these latter three)" what percentage of OBD-II vehicles have these three PIDs available(I've learned that just because there's a sensor,doesn't mean there's a PID offered in some cases).-Keith
  10. #50
    Sep 2008
    Quote Originally Posted by Keith55555 View Post
    Excluding IAT, I have not come across a car that did not support some combination of Speed, RPM, MAP or MAF so that Ii could compute MPG. I have only not found IAT on some 1997 and older vehicles.
