Well, i personally havent done this hook up yet (and with an 87 camry i kinda cant) but from what i know....
There is a converter from the OBDII to a serial connection.
There are many out there and i even read about one that i believe was USB.
Most that i have seen come with their own software for monitoring purposes. Also, if you check out the front end section, i have seen some who have integrated it into their set up. One had road runner displaying a speedometer and tach.
This probably wasnt much help, but i do know there are MANY on this site who have done it. You may want to check out the front end section for programming tips.
Good luck.
LinkBack URL
About LinkBacks
. There is a company called Multiplex Engineering which sells hardware which would allow you to tie your interface to your software ~ it is the interface that AutoEnginuity chose to go with. Many options, pick up an old ELM interface on eBay for $30 and start to play around, pick up some books and educate... then decide.
