Results 1 to 8 of 8
Thread: CAN protocol cable?
    FLAC djmickyg's Avatar
    Feb 2004
    CAN protocol cable?
    I'm finding it hard to find much info on the ford CAN protocol and the cabels seem to be much more expensive than they others.
    is anyone using a CAN with a read out..
    what cabel have you got..
    this is the chepest one i have found
    Ebay Linky
    all the others seem to be 2x the price..
    thanks
    mick
    Jul 2005
    Rosemount, MN
    It will be one of the cheapest out there because it is simply Ford + CAN. They actually use the old ELM320 chip plus a proprietery CAN interface. Most interfaces now support various protocols (not just Ford). That is why you see the difference in price.
    Feb 2004
    thanks
    can anyone recomend one??
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Quote Originally Posted by djmickyg
    Ford uses the more common 11-bit version of ISO15765, a multi-byte protocol that speaks on a CAN network. You don't need to look specifically for Ford compatibility; anything that claims CAN support should work fine. If some packages are more expensive than others, they might come with better software. Make sure to compare features!
    There's also a less common 29-bit version of ISO15765. I've seen more bugs in the the low-end software with this version, since some of the vendors don't have access to test vehicles. Expect this on some GM and some imports; just something to keep in mind.
    Jul 2005
    Rosemount, MN
    On a side note, the guys who make the TekMate software also make AutoEnginuity software.
    Newbie vagman's Avatar
    Jun 2006
    thats a fact that joel but they use elm chip with tekmate
    Jul 2005
    Rosemount, MN
    Yes and not the latest ELM chip either, they use (from what I have last heard) an older ELM chip, plus a proprietery CAN add on.
    Jun 2006
    pretty neandathol ,its like it fell of theark& came back in with the tide with a can addon lol.but idont want to sound like iam knocking it as it has done its jobbut its seeing the end of its times
  1. VGA Cable Question (Pinouts)
    By Bugbyte in forum LCD/Display
    Last Post: 07-26-2005, 09:54 AM
  2. FS: Modded Xenarc 20-pin Cable - 6 foot
    By hd54321 in forum Classified Archive
    Last Post: 05-27-2005, 03:54 PM
  3. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  4. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 04:45 PM
  5. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
