Results 1 to 5 of 5
Thread: OBD Setup / Linux
    May 2005
    OBD Setup / Linux
    Are you running an OBD setup using Linux? Could you please report your setup, including:
    - Flavor of Linux (Redhat, Slackware...)
    - Connection method (COM/USB)
    - Hardware Device (Andy, BR, etc)
    - Software Interface, custom?
    I'm curious as to the best route to go. Thanks.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    opensuse 10
    com
    ALDL custom wire
    java custom software.
    but i took linux out of my carputer so just windows now, but since program in java works on anything.
    oh but this is on an 22 year old car with gm obd-1.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    JML
    JML is offline
    Apr 2006
    Porto, Portugal
    I use a self improved version of scantool/freediag from freediag.sourceforge.net with a home compiled kernel 2.4.
    I already tested sucessefuly the same software in a standard DSL distribution.
    DSL is based on knoppix and knoppix is based on debbian...
    My hardware is a AlfaDiag KKL from Andy:
    http://www.ecufix.com/shop/index.php...roducts_id=181
    I can read errorcodes, MIL status and the folowing realtime data from my 2003 Mercedes-Benz E-Class:
    Code:
    Parameter                      Current         FreezeFrame
    Calculated Load Value           49.4%          -----
    Engine Coolant Temperature      82C            -----
    Intake Manifold Pressure       124kPaA         -----
    Engine RPM                      1846RPM        -----
    Vehicle Speed                   19km/h         -----
    Intake Air Temperature          40C            -----
    Air Flow Rate                   27.41gm/s      -----
    Time since motor start           442seg        -----
    Fuel Pressure                  170.00kPa       -----
    Warm-ups since codes cleared      255          -----
    Distance since codes cleared   11605km         -----
    Barometric Pressure             101kPa         -----
    Control module voltage         13.976V         -----
    Regards
    JML
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    I realise this thread is now thoroughly dated, but I thought I'd pimp myself anyways, just in case anyone is subscribed to this thread.
    I've written a tool called OBD GPS Logger that runs on Linux and OSX. It has its own sub-forum on these forums here: http://www.mp3car.com/vbulletin/obdii-gps-logger/. I just finished doing a new release that adds a UI, so now it's starting to look like something someone other than me might actually want to use...
    The homepage is here: http://icculus.org/obdgpslogger/
    Have fun,
    Gary (-;
    Aug 2011
    Texas
    question on your software
    Quote Originally Posted by 84RegalRider View Post
    opensuse 10
    com
    ALDL custom wire
    I am interested in the program you are using, since I am running a Ford with ODB-I. I realize that Ford and GM ODB-I programs are not the same, but hopefully I could find a Ford version where you got your program from. Many years back I remember a gentleman who wrote one (don't remember which flavor) and it was available for download. That was many moons and a computer or two back.
    My vehicle is circa 1992.
  1. Possible EPIA distro for Linux, Can we make one?
    By adamis in forum Software & Software Development
    Last Post: 02-23-2005, 06:50 PM
  2. Carputer setup critique?
    By carterparks in forum General Hardware Discussion
    Last Post: 12-30-2004, 12:08 PM
  3. help with my wifi setup?
    By ŠuTcH in forum Wireless Communications
    Last Post: 12-06-2004, 12:10 AM
  4. PS2 Linux ?'s
    By jws95hardbody in forum Newbie
    Last Post: 01-11-2004, 11:18 PM
  5. Help with linux boot...
    By cyrocr in forum General MP3Car Discussion
    Last Post: 11-12-2003, 09:08 AM
