Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: ODB II C# Style
  1. #11
    Newbie dwhite's Avatar
    Jun 2006
    Detroit, MI
    Sorry. Good luck
    Check out my company
  2. #12
    Feb 2006
    Schaumburg, IL
    My guess is the reason your car wont start without the guages plugged in is because most ins. clusters is where the ODO info is stored. So i bet there is some type of protection so you cant drive around for a year and your car not log any miles. So your best bet is to find some way to keep those guages installed somewhere.
    2003 Ford F-250 7.3L Diesel Crew Cab
    Pictures of my truck, hobbies, and more HERE
  3. #13
    Sep 2003
    Orlando
    i made a lot of progress on this so far, too lazy to takethe pictures off my digital camera, but got the whole system working now. Currently fabricating dashboard from scratch (like those guys doing Alpine cars). pics coming soon.
    Ignorant people are uneducated!
  4. #14
    Sep 2003
    Orlando
  5. #15
    Jul 2006
    Wow! You were serious! Is that MDF you're using to make your dash? It's not suitable for outdoor use. It needs to be sealed with water-thin epoxy to turn it into a composite. Otherwise it will soak up moisture like a sponge (humidity???) and start to smell. Not to mention it will swell when it gets wet. . .
  6. #16
    Sep 2003
    Orlando
    Cool
    what do you mean its not suitable for outdoor use. I'm not using it outdoor. Its going to be fleeced off and protected. Its what everyone uses to build custom car interiors.
    Where did you get that info?
  7. #17
    Jul 2006
    Well, most people look for what's easiest and don't think about things like what will last and what won't. MDF is great because it is cheap and it is dimensionally stable, meaning it won't tend to warp. But, with that said, it is made from wood particles and it soaks up moisture almost like a sponge.
    A car is indeed an outdoor space because it is exposed to the environment. Even cars that are stored in the garage when not being driven are exposed to humidity. The MDF will soak up the moisture in the air and it can swell somewhat if it gets moist enough. But, the real problem is that moisture will cause it to smell! If you want that good old musty smell in your car, well you get the idea.
    If I were building parts out of this stuff, I'd get some water-thin epoxy and brush it on all the parts. Not only will this seal it to protect against moisture, but it will make the material much stronger. It will become a composite material that is durable and resistant to the ravages of the environment. But, expoxy is not cheap! And, of course, this adds some labor and effort to the project.
    It all depends on your attitude. Do you want to build something to use it for a while and then get rid of it? Or do you want it to last a lifetime? It's up to you.
  1. ODB II and GM DIC
    By cw95403 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-22-2008, 02:40 AM
  2. What the cheaper and best ODB II to buy?
    By TimStark in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2005, 01:43 AM
  3. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
  4. Newbie question about ODB I and II
    By Nokia6600 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2004, 11:59 PM
  5. does my car have odb ii
    By essentialcruise in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-23-2003, 09:07 PM
